pi@octopi:~ $ sudo dmesg -w
[sudo] password for pi:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.63-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1496 SMP Wed Dec 1 15:58:11 GMT 2021
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] On node 0 totalpages: 229376
[ 0.000000] DMA zone: 2016 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 229376 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227360
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=24b112e1-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 826028K/917504K available (10240K kernel code, 1311K rwdata, 2948K rodata, 1024K init, 859K bss, 25940K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32054 entries in 63 pages
[ 0.000000] ftrace: allocated 63 pages with 6 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000025] Switching to timer-based delay loop, resolution 52ns
[ 0.000312] Console: colour dummy device 80x30
[ 0.001172] printk: console [tty1] enabled
[ 0.001240] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001298] pid_max: default: 32768 minimum: 301
[ 0.001522] LSM: Security Framework initializing
[ 0.001782] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001832] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003312] cgroup: Disabling memory control group subsystem
[ 0.003600] CPU: Testing write buffer coherency: ok
[ 0.004121] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005384] Setting up static identity map for 0x100000 - 0x10003c
[ 0.005594] rcu: Hierarchical SRCU implementation.
[ 0.006541] smp: Bringing up secondary CPUs ...
[ 0.007723] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009003] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010349] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010505] smp: Brought up 1 node, 4 CPUs
[ 0.010560] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.010591] CPU: All CPU(s) started in HYP mode.
[ 0.010618] CPU: Virtualization extensions available.
[ 0.011622] devtmpfs: initialized
[ 0.029298] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.029585] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.029647] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.032894] pinctrl core: initialized pinctrl subsystem
[ 0.034131] NET: Registered protocol family 16
[ 0.038379] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.044106] audit: initializing netlink subsys (disabled)
[ 0.045037] thermal_sys: Registered thermal governor 'step_wise'
[ 0.045891] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.046120] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.046162] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.046471] Serial: AMBA PL011 UART driver
[ 0.064874] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080148] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:08:00, variant start_x
[ 0.090159] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[ 0.134468] Kprobes globally optimized
[ 0.139475] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.141864] SCSI subsystem initialized
[ 0.142147] usbcore: registered new interface driver usbfs
[ 0.142235] usbcore: registered new interface driver hub
[ 0.142327] usbcore: registered new device driver usb
[ 0.144322] clocksource: Switched to clocksource arch_sys_counter
[ 1.917880] VFS: Disk quotas dquot_6.6.0
[ 1.918025] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.918250] FS-Cache: Loaded
[ 1.918505] CacheFiles: Loaded
[ 1.929110] NET: Registered protocol family 2
[ 1.929421] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.930979] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.931151] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.931297] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.931511] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.931711] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.931789] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.932125] NET: Registered protocol family 1
[ 1.933118] RPC: Registered named UNIX socket transport module.
[ 1.933155] RPC: Registered udp transport module.
[ 1.933184] RPC: Registered tcp transport module.
[ 1.933212] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.935058] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.938857] Initialise system trusted keyrings
[ 1.939167] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.948807] zbud: loaded
[ 1.950898] FS-Cache: Netfs 'nfs' registered for caching
[ 1.951788] NFS: Registering the id_resolver key type
[ 1.951859] Key type id_resolver registered
[ 1.951889] Key type id_legacy registered
[ 1.952073] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.952108] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.953331] Key type asymmetric registered
[ 1.953365] Asymmetric key parser 'x509' registered
[ 1.953452] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.953493] io scheduler mq-deadline registered
[ 1.953522] io scheduler kyber registered
[ 1.958580] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.970469] Console: switching to colour frame buffer device 82x26
[ 1.977773] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 1.988449] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.991447] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.997472] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.015157] brd: module loaded
[ 2.030028] loop: module loaded
[ 2.034526] Loading iSCSI transport class v2.0-870.
[ 2.038793] libphy: Fixed MDIO Bus: probed
[ 2.041674] usbcore: registered new interface driver lan78xx
[ 2.044400] usbcore: registered new interface driver smsc95xx
[ 2.046947] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.777729] Core Release: 2.80a
[ 2.780209] Setting default values for core params
[ 2.782664] Finished setting default values for core params
[ 2.985528] Using Buffer DMA mode
[ 2.987991] Periodic Transfer Interrupt Enhancement - disabled
[ 2.990533] Multiprocessor Interrupt Enhancement - disabled
[ 2.993064] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.995556] Dedicated Tx FIFOs mode
[ 2.998558] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b4104000 dma = 0xf4104000 len=9024
[ 3.005513] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.016389] dwc_otg: Microframe scheduler enabled
[ 3.016468] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.020794] WARN::hcd_init_fiq:458: FIQ ASM at 807c9984 length 36
[ 3.025235] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[ 3.029704] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.032020] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.034428] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.036753] Init: Port Power? op_state=1
[ 3.038983] Init: Power Port (0)
[ 3.041489] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.046105] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.048571] usb usb1: Product: DWC OTG Controller
[ 3.050929] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
[ 3.053321] usb usb1: SerialNumber: 3f980000.usb
[ 3.056509] hub 1-0:1.0: USB hub found
[ 3.058945] hub 1-0:1.0: 1 port detected
[ 3.062569] dwc_otg: FIQ enabled
[ 3.062582] dwc_otg: NAK holdoff enabled
[ 3.062594] dwc_otg: FIQ split-transaction FSM enabled
[ 3.062611] Module dwc_common_port init
[ 3.062955] usbcore: registered new interface driver usb-storage
[ 3.065659] mousedev: PS/2 mouse device common for all mice
[ 3.069261] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.074529] sdhci: Secure Digital Host Controller Interface driver
[ 3.077053] sdhci: Copyright(c) Pierre Ossman
[ 3.080123] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 3.083329] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.086155] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.090564] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.093576] hid: raw HID events driver (C) Jiri Kosina
[ 3.096387] usbcore: registered new interface driver usbhid
[ 3.098983] usbhid: USB HID core driver
[ 3.106822] Initializing XFRM netlink socket
[ 3.109437] NET: Registered protocol family 17
[ 3.112056] Key type dns_resolver registered
[ 3.115175] Registering SWP/SWPB emulation handler
[ 3.117716] registered taskstats version 1
[ 3.120053] Loading compiled-in X.509 certificates
[ 3.123201] Key type ._fscrypt registered
[ 3.125561] Key type .fscrypt registered
[ 3.127886] Key type fscrypt-provisioning registered
[ 3.141952] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.144511] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.151603] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.155842] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.158320] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.185818] Indeed it is in host mode hprt0 = 00021501
[ 3.250398] sdhost: log_buf @ (ptrval) (f4107000)
[ 3.289444] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.293476] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.297474] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.302640] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.304816] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.310019] of_cfs_init
[ 3.312376] of_cfs_init: OK
[ 3.328325] Waiting for root device PARTUUID=24b112e1-02...
[ 3.367944] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.375747] mmc0: new high speed SDHC card at address 0001
[ 3.379318] mmcblk0: mmc0:0001 00000 29.5 GiB
[ 3.384997] mmcblk0: p1 p2
[ 3.394369] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.396892] Indeed it is in host mode hprt0 = 00001101
[ 3.468528] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.470812] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.503305] mmc1: new high speed SDIO card at address 0001
[ 3.634693] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.639327] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.642724] hub 1-1:1.0: USB hub found
[ 3.645345] hub 1-1:1.0: 5 ports detected
[ 3.875768] EXT4-fs (mmcblk0p2): recovery complete
[ 3.887141] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.892490] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.901211] devtmpfs: mounted
[ 3.911186] Freeing unused kernel memory: 1024K
[ 3.914483] Run /sbin/init as init process
[ 3.917173] with arguments:
[ 3.917184] /sbin/init
[ 3.917194] with environment:
[ 3.917206] HOME=/
[ 3.917217] TERM=linux
[ 3.964379] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.094751] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 4.100325] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.106156] smsc95xx v2.0.0
[ 4.495361] libphy: smsc95xx-mdiobus: probed
[ 4.499279] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:5f:d0:a7
[ 4.604392] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[ 4.721980] systemd[1]: System time before build time, advancing clock.
[ 4.750588] usb 1-1.4: New USB device found, idVendor=0483, idProduct=5740, bcdDevice= 0.00
[ 4.756317] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.759362] usb 1-1.4: Product: MARLIN_STM32F429VGT6 CDC in FS Mode
[ 4.762407] usb 1-1.4: Manufacturer: STMicroelectronics
[ 4.765474] usb 1-1.4: SerialNumber: 376336703330
[ 4.835967] NET: Registered protocol family 10
[ 4.840567] Segment Routing with IPv6
[ 4.914554] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.924827] systemd[1]: Detected architecture arm.
[ 5.038522] systemd[1]: Set hostname to .
[ 6.067317] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.090668] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.096089] systemd[1]: Created slice User and Session Slice.
[ 6.102718] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.106330] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.117605] systemd[1]: Created slice system-getty.slice.
[ 6.123724] systemd[1]: Reached target Slices.
[ 6.130186] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.140206] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.147225] systemd[1]: Listening on udev Control Socket.
[ 6.963152] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.078880] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 7.840826] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.844138] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.844179] [vc_sm_connected_init]: start
[ 7.857310] mc: Linux media interface: v0.10
[ 7.858333] [vc_sm_connected_init]: installed successfully
[ 7.941015] videodev: Linux video capture interface: v2.00
[ 7.961025] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.987263] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 8.037239] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.037246] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.039301] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.078201] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.078572] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.095135] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.284716] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.427219] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.533722] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 8.548378] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.550245] usbcore: registered new interface driver brcmfmac
[ 8.559747] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 8.562027] usbcore: registered new interface driver cdc_acm
[ 8.562045] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 8.720472] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.721035] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.721360] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.721425] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.721497] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.722031] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.722064] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.722089] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.722110] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.722131] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.722373] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.725588] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.725639] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.730408] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.730458] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.733782] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.733831] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.817429] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.817577] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.817667] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 8.818561] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
[ 10.905076] random: crng init done
[ 10.905105] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.969306] uart-pl011 3f201000.serial: no DMA platform data
[ 11.275169] 8021q: 802.1Q VLAN Support v1.8
[ 11.464381] Adding 102396k swap on /var/swap. Priority:-2 extents:4 across:223648k SSFS
[ 11.991274] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 12.576385] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
[ 12.576696] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 12.586675] smsc95xx 1-1.1:1.0 eth0: Link is Down
[ 13.455382] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.493814] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 16.194402] Bluetooth: Core ver 2.22
[ 16.194503] NET: Registered protocol family 31
[ 16.194511] Bluetooth: HCI device and connection manager initialized
[ 16.194541] Bluetooth: HCI socket layer initialized
[ 16.194554] Bluetooth: L2CAP socket layer initialized
[ 16.194575] Bluetooth: SCO socket layer initialized
[ 16.207848] Bluetooth: HCI UART driver ver 2.3
[ 16.207863] Bluetooth: HCI UART protocol H4 registered
[ 16.207968] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.208234] Bluetooth: HCI UART protocol Broadcom registered
[ 16.494217] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.494232] Bluetooth: BNEP filters: protocol multicast
[ 16.494252] Bluetooth: BNEP socket layer initialized
