I'm struggeling to install the latest version of Octopi on my RaspberryPi
Downloaded octopi-buster-lite-0.17.0 and flashed it to a 16 Gb sandisk ultra.
Edited the octopi-wpa-supplicant with the name and password of my wifi router.
Put the sd card in the Pi, switched it on and tried to connect with octopi.local on port 22.
My putty responded no octopi.local found.
Put the 'older'version of octopi in the sd slot, switched on and connection with octopi.local on port 22 is succesfull.
I'm lost at this point.
Has anyone a clue?
Flashed te image 4 times on a row, same result.
Sorry no connection, no logs available.
