well, sorry to be the 1000st to bother you with this problem...I just can't get it to connect.
The board is found ("ch341-uart converter now attached to ttyUSB0"), but the serial connection doesn't establish.
Running on a raspi 4 Model B Rev 1.2, web-interface up and running, newest operating system (octopi 0.18.0, board creality 4.2.7, marlin 2.0.7.2)
- 3 different usb cables
- with and without strip on +5v pin
- reboot (pi)
- safe mode
- recompiled firmware (of printer) a few times
- changed baud rate
- tried everything on "Auto" and on manual config
yes, no change
Complete Logs
octoprint.log
2020-11-23 17:15:30,718 - octoprint.server.util.sockjs - INFO - New connection from client: 2003:c9:3700:3e00:edbb:55ec:339e:bd83
2020-11-23 17:15:30,821 - octoprint.server.util.flask - INFO - Passively logging in user _admin from 2003:c9:3700:3e00:edbb:55ec:339e:bd83
2020-11-23 17:15:30,821 - octoprint.access.users - INFO - Logged in user: _admin
2020-11-23 17:15:31,951 - octoprint.server.util.sockjs - INFO - User _admin logged in on the socket from client 2003:c9:3700:3e00:edbb:55ec:339e:bd83
2020-11-23 17:15:32,613 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.64
2020-11-23 17:15:38,110 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-11-23 17:15:38,112 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-11-23 17:15:38,149 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-11-23 17:16:01,496 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-11-23 17:16:01,506 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-11-23 17:16:06,977 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-11-23 17:16:07,006 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2020-11-23 17:16:07,006 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2020-11-23 17:16:07,007 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-11-23 17:16:07,047 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2020-11-23 17:16:07,050 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-11-23 17:16:09,052 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2020-11-23 17:16:09,058 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-11-23 17:16:11,060 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2020-11-23 17:16:11,065 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-11-23 17:16:13,068 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2020-11-23 17:16:13,110 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2020-11-23 17:16:13,152 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-11-23 17:16:13,261 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
2020-11-23 17:30:18,507 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-23 17:30:22,651 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 904}
serial.log
2020-11-23 17:32:17,361 - Enabling serial logging
2020-11-23 17:32:21,786 - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-11-23 17:32:21,813 - Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2020-11-23 17:32:21,814 - Trying port /dev/ttyUSB0, baudrate 115200
2020-11-23 17:32:21,815 - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-11-23 17:32:21,866 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:32:21,868 - Connected to: Serial<id=0x7f92eb2a58, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-11-23 17:32:21,869 - Send: N0 M110 N0*125
2020-11-23 17:32:23,872 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:32:23,886 - Send: N0 M110 N0*125
2020-11-23 17:32:25,887 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:32:25,903 - Send: N0 M110 N0*125
2020-11-23 17:32:27,908 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2020-11-23 17:32:27,952 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2020-11-23 17:32:27,960 - Connection closed, closing down monitor
2020-11-23 17:32:37,395 - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-11-23 17:32:37,397 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2020-11-23 17:32:37,397 - Trying port /dev/ttyUSB0, baudrate 115200
2020-11-23 17:32:37,398 - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-11-23 17:32:37,434 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:32:37,437 - Connected to: Serial<id=0x7f92d1d5c0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-11-23 17:32:37,438 - Send: N0 M110 N0*125
2020-11-23 17:32:39,441 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:32:39,447 - Send: N0 M110 N0*125
2020-11-23 17:32:41,449 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:32:41,455 - Send: N0 M110 N0*125
2020-11-23 17:32:43,458 - Trying port /dev/ttyUSB0, baudrate 250000
2020-11-23 17:32:43,467 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:32:43,477 - Send: N0 M110 N0*125
2020-11-23 17:32:45,479 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:32:45,491 - Send: N0 M110 N0*125
2020-11-23 17:32:47,492 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:32:47,504 - Send: N0 M110 N0*125
2020-11-23 17:32:49,502 - Trying port /dev/ttyUSB0, baudrate 230400
2020-11-23 17:32:49,506 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:32:49,516 - Send: N0 M110 N0*125
2020-11-23 17:32:51,518 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:32:51,531 - Send: N0 M110 N0*125
2020-11-23 17:32:53,532 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:32:53,545 - Send: N0 M110 N0*125
2020-11-23 17:32:55,546 - Trying port /dev/ttyUSB0, baudrate 57600
2020-11-23 17:32:55,549 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:32:55,563 - Send: N0 M110 N0*125
2020-11-23 17:32:57,559 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:32:57,572 - Send: N0 M110 N0*125
2020-11-23 17:32:59,573 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:32:59,586 - Send: N0 M110 N0*125
2020-11-23 17:33:01,587 - Trying port /dev/ttyUSB0, baudrate 38400
2020-11-23 17:33:01,591 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:33:01,605 - Send: N0 M110 N0*125
2020-11-23 17:33:03,601 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:33:03,611 - Send: N0 M110 N0*125
2020-11-23 17:33:05,612 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:33:05,627 - Send: N0 M110 N0*125
2020-11-23 17:33:07,628 - Trying port /dev/ttyUSB0, baudrate 19200
2020-11-23 17:33:07,631 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:33:07,645 - Send: N0 M110 N0*125
2020-11-23 17:33:09,638 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:33:09,652 - Send: N0 M110 N0*125
2020-11-23 17:33:11,647 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:33:11,660 - Send: N0 M110 N0*125
2020-11-23 17:33:13,658 - Trying port /dev/ttyUSB0, baudrate 9600
2020-11-23 17:33:13,661 - Handshake attempt #1 with timeout 2.0s
2020-11-23 17:33:13,671 - Send: N0 M110 N0*125
2020-11-23 17:33:15,667 - Handshake attempt #2 with timeout 2.0s
2020-11-23 17:33:15,680 - Send: N0 M110 N0*125
2020-11-23 17:33:17,675 - Handshake attempt #3 with timeout 2.0s
2020-11-23 17:33:17,687 - Send: N0 M110 N0*125
2020-11-23 17:33:19,684 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2020-11-23 17:33:19,724 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2020-11-23 17:33:19,728 - Connection closed, closing down monitor
dmesg
[ 4884.376958] ch341 1-1.1:1.0: device disconnected
[ 6925.460607] usb 1-1.1: new full-speed USB device number 7 using xhci_hcd
[ 6925.566799] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 6925.566816] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 6925.566828] usb 1-1.1: Product: USB Serial
[ 6925.575579] ch341 1-1.1:1.0: ch341-uart converter detected
[ 6925.581016] usb 1-1.1: ch341-uart converter now attached to ttyUSB0
I know this is coming up all the time, anyhow I'd really appreciate a hint or an idea to solve this. Hope I didn't forget anything necessary - if any other info is needed, I will provide (if I can).
edit: sorry for the ugly logs, I tried to put them in with scrollbars, but I don't know how ..
