Octoprint (on a Pi) didn't recognize the Sidewinder X1 Printer.
It worked for years - and then from one day to the other it didn't work anymore.
Connection to Pronterface is possible.
tried to change several configurations in serial connection Tab.
Reinstalled a fresh octopi
yes
no
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.4.1 Safari/605.1.15
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 1908686848
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.9.3-20231009151442
env.plugins.pi_support.octopiuptodate_build_short: 2023.10.09.151442
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.3
systeminfo.generated: 2024-04-17T14:48:58Z
systeminfo.generator: zipapi
See above
Printer is an Artillery Sidewinder x1 v4
I would suggest enabling the serial.log (click blue link for instructions) and the uploading another systeminfo bundle. This should show us the communication details and hopefully why you have a "Disconnect" button instead of a "Connect" button.
You say that Pronterface works so could you provide a screenshot of that when it is connected to your printer? Send the following commands and then another screenshot.
From the bundle you provided: Performing autodetection with 0 port/baudrate candidates: indicates that OctoPrint isn't finding your printer because it doesn't have a list of ports or baud rates to try. I don't recognize /dev/tty.BLTH as a serial port on OctoPi 1.0.0 so maybe OctoPrint doesn't either.
Moving on to the commands you sent to the printer...
The M109 (hotend) worked but M190 (bed) did not. Does this printer have a heated bed?
I believe the only issue we need to solve is the lack of choices for the serial port. Under OctoPrint Settings, Serial Connection, Additional serial ports you should add /dev/tty.BLTH if that is indeed the serial port that pronterface is successfully connecting to. The baud rate looks "normal" so that shouldn't need any changes.
