Hello Community,
I'm getting really desperate. I'm trying to connect my Creality Ender 5 to my new Octoprint instance. Without any success. I went through the installation process as normal and can access the user interface without any problems. However, when I try to connect to the printer, I always get the following error message:
Status: Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)
I get this error message both when the printer is connected and when it is not connected.
I've tried to rule out most sources of error. I bought an original power supply unit on the Pi and a mini USB cable with a data channel. I also tried another USB cable, without success. So it shouldn't be that.
Different ways of connection (switch on printer first, then the Pi and vice versa) did nothing.
Yes.
No.
Complete Logs
Here is an excerpt from the logs for a connection attempt.
octoprint.log:
2021-01-31 20:54:02,403 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-01-31 20:54:02,434 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-01-31 20:54:02,435 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-01-31 20:54:02,436 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-01-31 20:54:02,490 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-01-31 20:54:02,657 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
serial.log:
2021-01-31 20:54:02,403 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-01-31 20:54:02,434 - Performing autodetection with 0 port/baudrate candidates:
2021-01-31 20:54:02,435 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-01-31 20:54:02,436 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
OctoPrint version: 1.5.3
OctoPi version: 0.18.0, running on Raspberry Pi 4 Model B Rev 1.4
Printer: Creality Ender 5
Printer firmware: 1.1.6.1
One thing that struck me: A colleague of mine also has the Ender 5. However, he only bought it new and a slightly newer software version. Everything works for him. His firmware version is 1.1.6.3. Mine is, as described, 1.1.6.1. Could it be because of that? I don't even get a little reply from the printer that he's there. The error message is always the same. I don't know what to do next and got lost in other forum posts. I can't figure that out either. Please let me know if you need more information. Can someone help me?
Many greetings
Martin
