i am trying to install octopi on a rapsberry pi 4 8GB, that i saw is not officially supported. i need to edit the /etc/default/octoprint script, but i am not able to find it in any way. i can't seem to find even the /etc/intit.d/octoprint script.
i tried to look on my already working octopi on a raspberri pi 3b+, and the scripts are where they are supposed to be
yes, it did not help.
Complete Logs
i am not sure which logs i should be posting here to help troubleshooting but the systemctl status octoprint returns:
β octoprint.service - The snappy web interface for your 3D printer
Loaded: loaded (/etc/systemd/system/octoprint.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-12-03 21:46:48 GMT; 35min ago
Main PID: 357 (octoprint)
Tasks: 11 (limit: 4915)
CGroup: /system.slice/octoprint.service
ββ357 /home/pi/oprint/bin/python3 /home/pi/oprint/bin/octoprint serve --host=127.0.0.1 --port=5000
Dec 03 21:46:54 octopi octoprint[357]: 2020-12-03 21:46:54,363 - octoprint.server.util.watchdog - INFO - ... initial scan done.
Dec 03 21:46:54 octopi octoprint[357]: 2020-12-03 21:46:54,383 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
Dec 03 21:46:54 octopi octoprint[357]: 2020-12-03 21:46:54,433 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
Dec 03 21:46:55 octopi octoprint[357]: 2020-12-03 21:46:55,077 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
Dec 03 21:46:55 octopi octoprint[357]: 2020-12-03 21:46:55,084 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
Dec 03 21:46:55 octopi octoprint[357]: 2020-12-03 21:46:55,085 - octoprint.util.pip - INFO - ==> pip ok -> yes
Dec 03 21:46:55 octopi octoprint[357]: 2020-12-03 21:46:55,094 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 52.9GB. That is considered sufficient for updating.
Dec 03 21:46:55 octopi octoprint[357]: 2020-12-03 21:46:55,549 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
Dec 03 22:01:52 octopi octoprint[357]: 2020-12-03 22:01:52,335 - octoprint.server.heartbeat - INFO - Server heartbeat <3
Dec 03 22:16:52 octopi octoprint[357]: 2020-12-03 22:16:52,337 - octoprint.server.heartbeat - INFO - Server heartbeat <3
OctoPrint version : 1.4.2
OctoPi version : 0.18.0
im on a raspberry pi 4 8GB
