No GCode View when Printing via Plugin
Whenever I print directly to OctoPrint via Cura Plugin, the GCode Viewer doesn't show the layers, plus I have no estimated print time.
Npothing that I can think of fixes the problem.
see above
octoprint-systeminfo-20240220142359.zip (597.5 KB)
OctoPrint 1.9.3, Raspberry Pi image with OctoPrint
Version 1.0.0, running on Raspberry Pi 3 Model B Rev 1.2
Printer is a Mingda Magician Pro with Firmware 1.6.7.5, I run Windows 10 and Firefox
Hello @CodeDaiki !
What plugin?
How do you manage to bypass OctoPrint for printing? How does that work?
Usually you upload your file to OctoPrint and OctoPrint does the print.
More notes on the Printer would be helpful.
Using this Plugin:
https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/OctoPrintPlugin
In the systeminfo bundle you've shared, it's showing that files are being transferred to the printer's SD card through OctoPrint. So most likely, your settings in the Cura OctoPrint plugin are to upload to the printer's SD card rather than locally to OctoPrint. For files on the printer's SD, OctoPrint doesn't have the information on the print so the gcode viewer and estimated time etc. are not available.
Gosh, I'm stupid as a loaf of bread. Thank you. I try to change the settings in Cura to not upload to the SD card. Thank you very much.
