No idea how to connect to the network
I can’t connect to the network. The server loads a bit but does not crash nor display any info. Raspberry pi flashes green at consistent intervals. I don’t know anything about networks or technical stuff at all, any solutions are gonna need to be dumbed down. Everything has worked flawlessly for years but all of a sudden it’s not working now.
Unplugged and plugged back in, removed and reinserted sd card
Cannot access safe mode
I don’t know how to even get this
Hardware you are trying to connect to, hardware you are trying to connect from, router, access point, used operating systems, ... **as
Raspberry pi (4?) to ender 3 via wifi
Can you temporarily connect the Pi via ethernet to your network/router/switch? Ethernet should be just plug and play on the Pi. Then you check on your router for the IP address of the Pi. Connect to that with your browser. If that works you can start to search for the reason why WiFi does not work.
You could connect the pi via HDMI to a monitor and edit the wps_supplicant.conf file like this:
First type in sudo nano /etc/wpa_supplicant/wpa_supplicant.conf,
than type this:
country=US  # or EN, depending on where you live
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
    ssid="YourSSID"
    psk="YourPassword"
    key_mgmt=WPA-PSK
    priority=1
in and save the file.
Now run sudo systemctl restart wpa_supplicant and the pi should be connectet to your Network!
It's more easy to start raspi_config
