When I run 'octoprint serve' on Windows 10, python 3.8.2, I receive an error ModuleNotFoundError: No module names 'netifaces'
I removed and reinstalled Python and reinstalled octoprint without error (logs avavilable)
Complete Logs
'cmd window output'
(venv) c:\OctoPrint>octoprint serve
File "c:\program files\python38\lib\runpy.py", line 194, in run_module_as_main
return run_code(code, main_globals, None,
File "c:\program files\python38\lib\runpy.py", line 87, in run_code
exec(code, run_globals)
File "C:\OctoPrint\venv\Scripts\octoprint.exe_main.py", line 7, in
File "c:\octoprint\venv\lib\site-packages\octoprint_init.py", line 625, in main
from octoprint.util.fixes import patch_sarge_async_on_py2
File "c:\octoprint\venv\lib\site-packages\octoprint\util_init.py", line 40, in
from octoprint.util.net import interface_addresses, address_for_client, server_reachable
File "c:\octoprint\venv\lib\site-packages\octoprint\util\net.py", line 16, in
import netifaces
ModuleNotFoundError: No module named 'netifaces'
### Additional information about your setup OctoPrint version - 1.4.2-py2.py3-none-any.whl, OctoPi version - not running on Pi, printer - Anycubic MEga 3s not connected, firmware, browser, operating system,-Win 10 ... **as much data as possible**WRITE HERE
OctoPrint version - 1.4.2-py2.py3-none-any.whl, OctoPi version - not running on Pi, printer - Anycubic MEga 3s not connected, firmware, browser, operating system,-Win 10 ... as much data as possible
