I connected a Raspberry Pi Zero 2 to the EINSY RAMBo of my Prusa i3 MK3S, following Prusa's guide exactly. Attempting to connect gives me the error: Offline after error
No more candidates to test, and no working port/baudrate combination detected.
I've been looking for solutions everywhere and it's just people saying they fixed it by trying a different USB cable. But this isn't powered by USB, it's via pins directly to the Prusa
Changed the baudrate from auto to all the different values. Restarted Octoprint. Restarted the system. Restarted the printer. Made sure I had a good physical connection. RPi port is set to on.
Performing autodetection with 0 port/baudrate candidates:
Changing monitoring state from "Detecting serial connection" to "Error"
