Unable to connect to port ttyACM0. ERROR MESSAGE: Offline after error No more candidates to test, and no working port/baudrate combination detected.
When typing dmesg in raspberry cmd, I get "Device not responding to setup address". It DOES read that this is a printer.
Wiped SD, used Balena to reinstall image, and basically restarted octoprint from scratch.
Manually put in necessary USB port into "Additional Serial Ports", but is still not recognized. I retrieved this port by disconnecting and connecting printer and getting dmesg logs (attached below).
I have tried many different USB cables, to the point of buying a new one specifically for this, to no avail.
Also deleted some USB port as per this blog post --> Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)
Didnt do anything, and hopefully didn't break any more.
Installed Malyan/Monoprice Connection Fix (0.1.3). This worked when I first bought the printer and installed octoprint. Now no longer works.
pi@octopi:~ $ dmesg | tail -n 20
[  389.613196] usb 1-1.1: Product: Malyan 3D Printer
[  389.613206] usb 1-1.1: Manufacturer: Malyan System
[  389.613218] usb 1-1.1: SerialNumber: 2073394C4352
[  389.681408] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
[  389.683767] usbcore: registered new interface driver cdc_acm
[  389.683776] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  390.914260] usb 1-1.1: USB disconnect, device number 3
[  392.305768] usb 1-1.1: new full-speed USB device number 4 using xhci_hcd
[  820.227734] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
[  820.328218] usb 1-1.3: Device not responding to setup address.
[  820.547941] usb 1-1.3: Device not responding to setup address.
[  820.767693] usb 1-1.3: device not accepting address 5, error -71
[ 1136.446319] usb 1-1.4: new full-speed USB device number 7 using xhci_hcd
[ 1136.593653] usb 1-1.4: New USB device found, idVendor=2974, idProduct=0503, bcdDevice= 2.00
[ 1136.593673] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1136.593687] usb 1-1.4: Product: Malyan 3D Printer
[ 1136.593698] usb 1-1.4: Manufacturer: Malyan System
[ 1136.593708] usb 1-1.4: SerialNumber: 2073394C4352
[ 1136.598500] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 1137.427985] usb 1-1.4: USB disconnect, device number 7
octoprint-systeminfo-20220118003314.zip (32.8 KB)
Raspberry PI 4B
Monoprice Select Mini v2
CableCreation USB Male to MicroUSB Cable
