No ports showing in Octoprint using UART via GPIO on Pi 5
Octoprint won't show any serial ports, but shows message:
No serial port found, are you sure your printer is physically connected and supported? Try [refreshing](javascript:void(0)) and if that doesn't help please see the FAQ.
These commands through SSH to the Pi 5 give results as follows:
pytho@CTCi3ProB:~ $ ls -l /dev/ttyAMA*
crw-rw---- 1 root dialout 204, 64 Jan 16 17:48 /dev/ttyAMA0
crw-rw---- 1 root dialout 204, 74 Jan 16 17:54 /dev/ttyAMA10
pytho@CTCi3ProB:~ $ ls -l /dev/serial*
lrwxrwxrwx 1 root root 7 Jan 16 17:39 /dev/serial0 -> ttyAMA0
I added Additional Serial Ports to Octoprint:
/dev/serial0
/dev/ttyAMA0
/dev/ttyAMA10
Yet no serial connection works after trying all these ports.
I just get this output in Terminal for each port tried:
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0x7ffed9687610, open=True>(port='/dev/ttyAMA10', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
No answer from the printer within the connection timeout, trying another hello
Send: N0 M110 N0125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Why?
Didn't do it.
octoprint-systeminfo-20240116182303.zip (327.6 KB)
What kind of hardware precisely, OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... as much data as possible
I had Octoprint Version 1.9.3 installed on my Raspberry Pi 5 and working over USB connection to BigTreeTech SKR 3 EZ motherboard. I want to change over to using UART via GPIO so made up a cable with crossover on RX and TX, connecting GND/PA9/PA10 on SKR3 to GND/GPIO14/GPIO15 on Pi 5. I used "sudo raspi-config" to turn off serial console but keep serial port active. Config.txt has dtparam=uart0_console=on. Cmdline.txt has console=serial0,115200 console=tty1 root= ...etc.
