Hi guys, I have a RPi Zero 2W with the official OctoPi image on it, it boots properly, I can see at the boot the IP that it was given. After logging in I use the command 'ip a' to see all the connection and I can see that the wifi network it's on. All good so far. The problem is that I cannot connect to the Octopi in any way remotely, not with IP nor the name, not to ssh into it, nothing. Can anyone had a similar issue and a solution as well please?
Ibdid try with my phone too, but the same. When I got home it start working. It was the work network, full of weird restriction. Thank you so much! By the way, have you heard/know anyone that is controling with octopi or similar a laser engraver?
But I can tell you a few general things:
Depending of the type of engraver and the firmware it works sometimes out of the box (with Marlin firmware for example) and other times with firmwares like GRBL you should use a plugin like this one
