Started up printer, connnected via serial on the UART just like normal. Attempted to home printer via controls and no response. Manually homed printer. Uploaded file to print and noticed no change in temps. Cancelled print and manually printed file from printer with success. I have webcam but, I have no response on controls or temps from printer. Last time I used Octoprint everything worked flawless which was about a week ago.
Tried restarting server and different browser (Internet Explorer). Currently trying Chrome just as before (version 79.0.3945.88)
Here is serial.log
Blockquote2020-01-03 12:18:47,975 - Connecting to: /dev/ttyAMA0
2020-01-03 12:18:47,994 - Changing monitoring state from "Offline" to "Opening serial port"
2020-01-03 12:18:48,000 - Connected to: Serial<id=0xa8f69510, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-01-03 12:18:48,005 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-01-03 12:18:48,024 - Send: N0 M110 N0125
2020-01-03 12:18:48,026 - Send: N0 M110 N0125
2020-01-03 12:18:48,056 - Recv: N0 ]`1� s�����00OLNnd38�������������� 0xff index:0 len:8,line:16284,s:�������_�*//Unknown opt: o( 0x6f index:0 len:15,line:16284,s:o��m����7/125*
2020-01-03 12:19:03,036 - Recv: ok
2020-01-03 12:19:03,045 - Changing monitoring state from "Connecting" to "Operational"
2020-01-03 12:19:03,058 - Send: N0 M110 N0125
2020-01-03 12:19:03,068 - Recv: �����~~�//Unknown opt: ? 0x3f index:1 len:15,line:16284,s:N?�m�9�>O<+�3��
2020-01-03 12:19:18,068 - Recv: ok
2020-01-03 12:19:18,074 - Send: N1 M11539
2020-01-03 12:19:18,082 - Recv: �LHSLLM��'�//Unknown opt: � 0xff index:0 len:2,line:16284,s:��
2020-01-03 12:19:33,090 - Recv: ok
2020-01-03 12:19:33,096 - Send: N2 M2118
2020-01-03 12:19:33,099 - Recv: N2 M2118
2020-01-03 12:19:48,102 - Recv: ok
2020-01-03 12:19:48,108 - Send: N3 M10536
2020-01-03 12:20:03,113 - Recv: �&���R��R�ok
2020-01-03 12:20:18,125 - Recv: ok
2020-01-03 12:20:18,131 - Send: N4 G9121
2020-01-03 12:20:18,134 - Recv: N4 G9121
2020-01-03 12:20:33,137 - Recv: ok
2020-01-03 12:20:33,143 - Send: N5 G28 Z092
2020-01-03 12:20:33,146 - Recv: N5 G28 Z092
2020-01-03 12:20:48,149 - Recv: ok
2020-01-03 12:20:48,155 - Send: N6 G9022
2020-01-03 12:20:48,163 - Recv: N� t�B�R�//Unknown opt: � 0xeb index:0 len:5,line:16284,s:�����
2020-01-03 12:20:49,495 - Connection closed, closing down monitor
2020-01-03 12:20:49,503 - Changing monitoring state from "Operational" to "Offline"
2020-01-03 12:21:17,107 - Connecting to: /dev/ttyAMA0
2020-01-03 12:21:17,117 - Changing monitoring state from "Offline" to "Opening serial port"
2020-01-03 12:21:17,124 - Connected to: Serial<id=0xa8f80f30, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-01-03 12:21:17,125 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-01-03 12:21:17,151 - Send: N0 M110 N0125
2020-01-03 12:21:17,154 - Send: N0 M110 N0125
2020-01-03 12:21:17,185 - Recv: N0"���~���H�/sd cmD error cnt:0 len:12 :M1���O�535�
2020-01-03 12:21:17,186 - Recv: ok
2020-01-03 12:21:17,188 - Changing monitoring state from "Connecting" to "Operational"
2020-01-03 12:21:17,193 - Send: N0 M110 N0125
2020-01-03 12:21:17,194 - Recv: //Unknown opt: � 0xea index:0 len:13,line:0,s:�zM�����V���R
2020-01-03 12:21:17,197 - Recv: N q!
2020-01-03 12:21:17,210 - Recv: I ��r�//Unknown opt: � 0xff index:0 len:7,line:0,s:�������
2020-01-03 12:21:32,212 - Recv: ok
2020-01-03 12:21:32,221 - Send: N1 M11539
2020-01-03 12:21:32,229 - Recv: N1 M115b1//Unknown opt: � 0xff index:0 len:2,line:0,s:��
2020-01-03 12:21:47,235 - Recv: ok
2020-01-03 12:21:47,241 - Send: N2 M2118
2020-01-03 12:21:47,246 - Recv: N2 M2118
2020-01-03 12:22:17,258 - Recv: ok
�ok
2020-01-03 12:22:17,265 - Send: N3 M10536
2020-01-03 12:22:17,272 - Recv: N ����S�//Unknown opt: � 0xff index:0 len:4,line:0,s:����
2020-01-03 12:22:32,280 - Recv: ok
2020-01-03 12:22:32,286 - Send: N4 G9121
2020-01-03 12:22:32,295 - Recv: ������//Unknown opt: o 0x6f index:0 len:10,line:0,s:o>�g9}2��
2020-01-03 12:22:47,302 - Recv: ok
2020-01-03 12:22:47,308 - Send: N5 G1 Z-10 F20047
2020-01-03 12:22:47,322 - Recv: N5 G1 Z-10 F2004�//Unknown opt: � 0xbb index:0 len:2,line:0,s:�R
2020-01-03 12:23:02,324 - Recv: ok
2020-01-03 12:23:02,330 - Send: N6 G9022
2020-01-03 12:23:02,338 - Recv: ���\��//Unknown opt: � 0xba index:2 len:10,line:0,s:N7�g��+;��
2020-01-03 12:23:17,346 - Recv: ok
2020-01-03 12:23:17,354 - Send: N7 G9122
2020-01-03 12:23:17,362 - Recv: ��:����{�//Unknown opt: � 0xef index:0 len:8,line:0,s:����{���
2020-01-03 12:23:32,367 - Recv: ok
2020-01-03 12:23:32,373 - Send: N8 G28 Z081
2020-01-03 12:23:32,382 - Recv: ���Z�����|�//Unknown opt: � 0xef index:0 len:12,line:0,s:������[�����
2020-01-03 12:23:47,389 - Recv: ok
2020-01-03 12:23:47,395 - Send: N9 G9025
2020-01-03 12:23:47,398 - Recv: N9 G9025
2020-01-03 12:24:02,400 - Recv: ok
2020-01-03 12:24:02,406 - Send: N10 M10522
2020-01-03 12:24:02,413 - Recv: N00 SLH���Zr���������� 0xff index:0 len:2,line:0,s:��
2020-01-03 12:24:02,417 - Recv: //Unknown opt: � 8xff"indez:00len:1,line:0,s:�
2020-01-03 12:24:02,421 - Recv: //Unknown opt: � 0xdf index:0 len:4,line:0,s:����
2020-01-03 12:24:17,420 - Recv: ok
2020-01-03 12:24:17,426 - Send: N11 M10523
2020-01-03 12:24:17,429 - Recv: ��1@
2020-01-03 12:24:17,435 - Recv: ����)�//Unknown opt: 0x7f index:0 len:11,line:2,s:�o��������
2020-01-03 12:24:32,442 - Recv: ok
2020-01-03 12:24:32,448 - Send: N12 M10520
2020-01-03 12:24:32,456 - Recv: �n7t��R��R�//Unknown opt: � 0xef index:0 len:4,line:0,s:����
2020-01-03 12:24:47,464 - Recv: ok
2020-01-03 12:24:47,469 - Send: N13 M10521
2020-01-03 12:24:47,472 - Recv: N13 M10521
2020-01-03 12:25:02,475 - Recv: ok
2020-01-03 12:25:02,480 - Send: N14 M10518
2020-01-03 12:25:02,483 - Recv: N14 M10518
2020-01-03 12:25:17,487 - Recv: ok
2020-01-03 12:25:17,493 - Send: N15 M10519
2020-01-03 12:25:17,496 - Recv: N15 M105*19
Octoprint version 1.3.12, Octopi version 17, Qidi X-Max firmware v4.2.6.5, Windows 10
