I cant get Octopi to see my Ender 3 over Serial.
The error at the top ( No serial port found, are you sure your printer is physically connected and supported?)
Issue
I previously had it running perfect on the original 8-bit board using octopi and lots of plugins.
I upgraded to the 32-bit V4.2.7 board and now it cant see any serial.
I used a fresh new install of octopi with no plugins.
Tried safe mode still no serial detected.
Its the latest version of octpi and a raspberry pi 2 model B.
Running sudo dmesg | grep -i usb displays the following:
pi@octopi:~ $ sudo dmesg | grep -i usb
[ 0.165185] usbcore: registered new interface driver usbfs
[ 0.165299] usbcore: registered new interface driver hub
[ 0.165399] usbcore: registered new device driver usb
[ 0.165702] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.165983] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 2.334087] usbcore: registered new interface driver lan78xx
[ 2.337261] usbcore: registered new interface driver smsc95xx
[ 3.332280] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.334796] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.337388] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.345039] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 3.350010] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.352638] usb usb1: Product: DWC OTG Controller
[ 3.355218] usb usb1: Manufacturer: Linux 6.1.21-v7+ dwc_otg_hcd
[ 3.357872] usb usb1: SerialNumber: 3f980000.usb
[ 3.361469] hub 1-0:1.0: USB hub found
[ 3.367979] usbcore: registered new interface driver usb-storage
[ 3.391835] usbcore: registered new interface driver usbhid
[ 3.394486] usbhid: USB HID core driver
[ 3.696985] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.957339] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 4.645433] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.656543] hub 1-1:1.0: USB hub found
[ 4.997011] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 5.137419] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 5.151681] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.290121] SMSC LAN8700 usb-001:003:01: attached PHY driver (mii_bus:phy_addr=usb-001:003:01, irq=199)
[ 5.307181] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:61:97:03
[ 5.417059] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 5.574550] usb 1-1.2: New USB device found, idVendor=148f, idProduct=5370, bcdDevice= 1.01
[ 5.589236] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.599895] usb 1-1.2: Product: 802.11 n WLAN
[ 5.607547] usb 1-1.2: Manufacturer: Ralink
[ 5.614982] usb 1-1.2: SerialNumber: 1.0
[ 17.087094] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 17.268489] usbcore: registered new interface driver rt2800usb
