No Serial Port Found after new image
In order to update my Python, I took the easy method. I backed up my current Octoprint and copied it to my computer. Then I used a new sd card and Raspberry Pi Imager 2.0.6 to write a new image with the latest Octopi and Octoprint. After booting I get a message of 'No serial port found'. I put the original sd card back in the pi and it starts up just fine with a port of /dev/ttyUSB0. It doesn't seem like it should be this hard.
I switched cables, used another sd card, tried safe mode, searched the forum for a similar issue.
yes
octoprint-systeminfo-20260217142310.zip (13.3 KB)
OctoPrint: 1.11.6
OctoPi: 1.1.0
Raspberry Pi 3B v 1.2
Creality CR-10 Mini
Chrome browser
Windows 10
I don't think this is a hardware issue because I can pop the original sd card back in and everything works fine. I'm stuck.
Thanks for any help or suggestions.
I have my printer working but not sure I have completely solved the problem. I have always had the raspberry pi and the printer on the same power strip so they both turn on together and that has worked for years. I found now that if I turn on the pi first and wait until it finishes booting before I turn on the printer then I can open Octoprint. However, even though I have the check box selected to automatically connect, it does not. If I then press the Connect button, the printer connects and it starts to work.
The other issue has to do with the Filament Sensor Simplified plugin. If I go to the settings page for the plugin and use the test senor function, it works correctly - shows when the filament is and is not present. However it doesn't work when the printer is running. The icon on the header line never changes and, if I cut the filament, it doesn't stop or pause the print.
Is there a better or more recent plugin that will work?
Thanks,
Bob
