I took a break from printing and before then everything was working good. I decided to compile my own Marlin 2.1.2 firmware myself. Octoprint worked for a bit and now will not connect to my printer and says "No Serial Port Found"
I used 2 different pi 4s with a fresh install of Octoprint. The new board was working for a little and then stopped. As well I flashed my previous firmware on my board which did not fix the issue. My printer connects to my mac just fine when using Pronterface
Yes.
Briefly. It was working but then stopped after a few minutes.
octoprint.log (57.7 KB)
serial.log (198 Bytes)
haproxy.log (101.2 KB)
webcamd.log (1.6 MB)
I am using an Ender 3 Pro with a SKR mini E3V3.
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 1909071872
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.5
env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.8.6-20221018093204
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2023-02-08T18:23:34Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: True
octoprint.version: 1.8.6
systeminfo.generated: 2023-02-08T18:27:09Z
systeminfo.generator: zipapi
