<no signal> usb camera stream after using octoprint_deploy
USB Logitech QuickCam Easy Cool
The camera was working correctly when I was just using my Ender 3V2. After getting a second printer (Ender 3Pro) and using octoprint_deploy to create multiple instances, the camera stream no longer works. I seem to be able to connect to the stream, but webcam says, .
deleting the camera and readding the instance
changing streamers
turned off 2nd printer in case power draw was an issue
restarted webcam
edited boot/camera-streamer/libcamera.conf resolution down to 680x430, framerate of 5
edited boot/camera-streamer/usb-default.conf resolution down to 680x430, framerate of 5
Only the fully qualified url (http:///cam_Ender_3V2/?action=stream) gives the . Other suggested urls (localhost, raspberrypi.local, etc.) don't load.
Yes
octoprint-systeminfo-20250220191432.zip (101.8 KB)
Octoprint version: 1.10.3
OctoPi version: Build 2024.11.05.100055 with "camera-streamer", based on OctoPi 1.0.0, running on Raspberry Pi 4 Model B Rev 1.5
Printer: Ender 3V2
firmware:
browser: Chrome Version 133.0.6943.127 (Official Build) (64-bit)
system: 11 (bullseye)
I don't know what other information would be useful (or probably how to get it), so if you need something I omitted, please let me know what it is, and preferably how/where to get it.
hi i hadnt altered mine at all but today both webcams were showing no-signal, i restarted octoprint a couple of times with no luck , but after rebooting the pi its working again , might not be the fix for you but worth a try .
thanks
martin
Thanks for the suggestion. Rebooted several times without success. I'm pretty sure it's a configuration issue though as it hasn't been working since I virtualized and added the 2nd Octoprint instance. I'm guessing it's a driver or config file somewhere, I just don't know what I'm doing enough to know where to look or what to fix.
