No supplicant.txt file in flashed SD card
I can't get octoprint set up. I've downloaded and extracted the image file - 2020-12-02-octopi-buster-armhf-lite-0.18.0, but when I flash the SD card it only shows 32 files vs the 44 that are meant to be there. Of note, the upplicant.txt file is not there, so I cannot progress with setting up octoprint.
I've downloaded the .img file numerous times and flashed the SD card numerous times as well.
I'd really appreciate your help.
Kind regards,
Rory
Just to be sure - you know that the filename is octopi-wpa-supplicant.txt, right?
Finally got it working by downloading the .img file on another computer. Not sure what the issue was on mine, but hey, it's sorted now.
Great! So could you please:
