No update at all the way
No update, after all the guides in here i could not update, it is not on python 2.0, not on overheat, good power supply
every guide i could find on git hub, even sudo apt-get update && upgrade
YES
nein
octoprint-systeminfo-20220520234635.zip (41.6 KB)
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.84 Safari/537.36 OPR/85.0.4341.79
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1200
env.hardware.ram : 918188032
env.os.bits : 32
env.os.id : linux
env.os.platform : linux2
env.plugins.pi_support.model : Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version : 0.16.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 19.0.1
env.python.version : 2.7.13
env.python.virtualenv : true
octoprint.safe_mode : false
octoprint.version : 1.6.1
printer.firmware : Prusa-Firmware 3.11.0 based on Marlin
systeminfo.generator : systemapi
Hello @Carls_Zarigata !
Obviously it is.
I'll recommend making a backup and make a new installation with OctoPi 0.18.1.
when i go into SSH and type python it goes to 3.5.....
Python 2 and Python 3 can be installed side-by-side. You happen to start Python3 when logged in via SSH, but the system is still running OctoPrint with Python 2.
NB: Even if you were to uninstall Python 2 from your Pi (keeping only Python 3) without doing anything else, OctoPrint would still be running using Python 2, because OctoPrint is typically run from inside a "virtual environment", which is basically a local copy of Python (which in your case is still set up to use Python 2). In order to make OctoPrint run with Python 3 it does not suffice to install Python 3; you have to rebuild the virtual environment using Python 3.
