Message that shows in the log file that is ATTACHED to my original post....
2022-10-03 22:15:10,622 - octoprint.startup - INFO - ******************************************************************************
2022-10-03 22:15:10,626 - octoprint.startup - INFO - Starting OctoPrint 1.8.3
2022-10-03 22:15:10,627 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2022-10-03 22:15:10,627 - octoprint.startup - INFO - Reason for safe mode: problem during last startup
2022-10-03 22:15:10,627 - octoprint.startup - INFO - ******************************************************************************
2022-10-03 22:15:10,978 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2022-10-03 22:15:11,069 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2022-10-03 22:15:11,069 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2022-10-03 22:15:11,069 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2022-10-03 22:15:11,669 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)
2022-10-03 22:15:11,676 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2022-10-03 22:15:12,981 - octoprint.plugin.core - ERROR - Could not locate plugin googledrivefiles
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 1188, in _import_plugin_from_module
location, spec = _find_module(module_name)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 45, in _find_module
spec = imp.find_module(name)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 288, in find_module
raise ImportError(_ERR_MSG.format(name), name=name)
ImportError: No module named 'octoprint_googledrivefiles'
2022-10-03 22:15:13,068 - octoprint.plugin.core - INFO - Found 25 plugin(s) providing 18 mixin implementations, 38 hook handlers
2022-10-03 22:15:13,097 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2022-10-03 22:15:13,106 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/oprint/bin/octoprint", line 8, in
sys.exit(main())
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/init.py", line 936, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1130, in call
return self.main(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 330, in serve_command
disable_color=no_color,
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 163, in run_server
octoprint_server.run()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/init.py", line 371, in run
self._setup_app(app)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/init.py", line 1466, in _setup_app
from flask_limiter import Limiter
File "/home/pi/oprint/lib/python3.7/site-packages/flask_limiter/init.py", line 4, in
from .errors import RateLimitExceeded
File "/home/pi/oprint/lib/python3.7/site-packages/flask_limiter/errors.py", line 6, in
from .typing import Optional
File "/home/pi/oprint/lib/python3.7/site-packages/flask_limiter/typing.py", line 14, in
from typing_extensions import ParamSpec
ImportError: cannot import name 'ParamSpec' from 'typing_extensions' (/home/pi/oprint/lib/python3.7/site-packages/typing_extensions.py)
