I cannot access the octoprint webui from my browser (opera gx) and/or cannot use it in things like cura or prusaslicer.
I have reinstalled octoprint a couple times, tried every possible combination of link, ip, and port that I could think of. I have even went so far as to change firewall settings to allow my windows pc ip.
N/A
N/A
(Was able to access due to webui working on laptop)
I am running a custom klipper firmware on my Ender 3 V2 NEO, this problem also persisted with mainsail + moonraker before I ultimately went back to octoprint (love the plugins!). This is running on an old Acer Nitro 5 with a i9-9300h and igpu gtx 1050. I am using a fresh install of octoprint with octoklipper being my only plugin so far. I would have this figured out but I cannot even identify the source of the problem. Please help! (edit: laptop was converted to linux mint for the purpose of klipper alone. I had forgotten to mention this.)
And I just remembered this now: my old octoprint setup (pre-klipper) was on the stock windows OS on laptop, which worked fine on all local devices. Iβm starting to think it might be a weird Linux network config or just simply something that I missed
OK. Done some digging and apache AND haproxy were enabled...seems to be heading in a good direction. I may also unintall mainsail + moonraker to make absolute sure that they are not interfering. (and honestly, i might switch back after this debacle) (when using the 127 ip it brought up mainsail on laptop that was hosting. I have uninstalled both moonraker and mainsail and are hoping for results.)
SOLUTION: at this point I reinstalled mint, did not update anything (even though it REALLY pushes it), installed kiauh, then mainsail and moonraker and it just worked. so my solution/theory is: be careful when using mint. Do not update anything, only install kiauh. (I have not tried only relying on the bootstrapper yet, but it may work.) I am officially in business with klipper! (Worse case scenario, if nothing works, do what I did. Take you thumb drive which you installed mint with and do a complete wipe with install in bios. Make sure to not update or install anything else besides what I stated.)
