Hi, I can't get wifi working with the octopi-wpa-supplicant.conf file.
I tried setting up wifi manually with network interfaces, and managed to get an IP address (but no internet since I think there was a conflict with dhcpcd which I didn't bother to fix, because I'd like it to work the usual way), so the wifi dongle is recognized.
I searched on internet for several solutions, and nothing really work.
I edited the file with nano on manjaro, so it shouldn't be a problem.
I'm using a raspberry pi 2 with a usb wifi dongle.
I have access to the command line because I connected the Pi to an external screen and a keyboard.
Here is my octopi-wpa-supplicant.conf :
# Use this file to configure your wifi connection(s).
# Just uncomment the lines prefixed with a single # of the configuration
# that matches your wifi setup and fill in SSID and passphrase.
# You can configure multiple wifi connections by adding more 'network'
# blocks.
# See https://linux.die.net/man/5/wpa_supplicant.conf
# (or 'man -s 5 wpa_supplicant.conf') for advanced options going beyond
# the examples provided below (e.g. various WPA Enterprise setups).
# !!!!! HEADS-UP WINDOWS USERS !!!!!
# Do not use Wordpad for editing this file, it will mangle it and your
# configuration won't work. Use a proper text editor instead.
# Recommended: Notepad++, VSCode, Atom, SublimeText.
# !!!!! HEADS-UP MACOSX USERS !!!!!
# If you use Textedit to edit this file make sure to use "plain text format"
# and "disable smart quotes" in "Textedit > Preferences", otherwise Textedit
# will use none-compatible characters and your network configuration won't
# work!
## WPA/WPA2 secured
network={
ssid="my_super_ssid_checked_10x"
psk="my_super_passwd_checked_10x"
## Open/unsecured
#network={
# ssid="put SSID here"
# key_mgmt=NONE
## WEP "secured"
## WEP can be cracked within minutes. If your network is still relying on this
## encryption scheme you should seriously consider to update your network ASAP.
#network={
# key_mgmt=NONE
# wep_key0="put password here"
# wep_tx_keyidx=0
# Uncomment the country your Pi is in to activate Wifi in RaspberryPi 3 B+ and above
# For full list see: https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2
#country=GB # United Kingdom
#country=CA # Canada
#country=DE # Germany
country=FR # France
#country=US # United States
### You should not have to change the lines below #####################
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
All help appreciated
