Hi, I'm a total noob and this is my first post. I'm settin gup octoprint on my old windows 10 laptop through a youtube video and got the octo server to work but ater I put ' --host= 'my ip4'--port=5000' it doesn't go further then the 'preemptive caching' line as you can see under here.
My cmd doesn't go further then this:
2021-09-26 12:07:40,657 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2021-09-26 12:07:40,657 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-09-26 12:07:40,924 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay_py2.json
2021-09-26 12:07:41,566 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on Acerlaptop._http._tcp.local.' for _http._tcp.local.
2021-09-26 12:07:42,490 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on Acerlaptop._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-09-26 12:07:42,490 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on Acerlaptop for SSDP
2021-09-26 12:07:42,506 - octoprint.server - INFO - Listening on http://192.168.1.164:5000
2021-09-26 12:07:42,615 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-09-26 12:07:43,273 - octoprint.util.pip - INFO - Using "c:\python27\python.exe -m pip" as command to invoke pip
2021-09-26 12:07:43,273 - octoprint.util.pip - INFO - pip installs to c:\python27\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> no
2021-09-26 12:07:43,273 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-09-26 12:07:43,305 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 382.2GB. That is considered sufficient for updating.
2021-09-26 12:07:44,007 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://localhost:5000/'}
2021-09-26 12:07:44,602 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-09-26 12:07:45,825 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-09-26 12:07:52,430 - octoprint.server.preemptive_cache - INFO - ... done in 8.42s
Look up other forum posts here that contain the word premptive caching without succes
