I am unable to connect to Octoprint on my Raspberry Pi 4b using http://octopi.local. Also unable to ssh into it. I followed the instructions here.
- Reinstalled multiple times
- Researched the issue on this forum and Reddit. Including the Wifi megathread. Nothing seemed to help.
- Installed Raspbian to ensure that it was not a hardware issue. Raspbian was able to connect to my Wifi fine (albeit taking a slightly long time to connect) and I was able to ssh into it using the IP.
- Tried directly editing octopi-wpa-supplicant.txt with my wifi settings.
I don't have any logs because I can't figure out how to produce them in this instance.
It is a resident network for the apartment I live in. I doubt they have these kinds of connections blocked because ssh was not blocked and they are really lazy with tech and maintenance.
The Octopi image is on a Raspberry Pi 4b with Octopi installed from Imager, I am trying to connect from a desktop PC on the same network which uses Arch Linux. I also tried connecting with my phone, which uses LineageOS.
Here is my wifi supplicant file in case there are any issues (ssid and password obviously not the actual ones):
## WPA/WPA2 secured
network={
ssid="MyApartmentSSID"
psk="MyApartmentPassword"
## Open/unsecured
#network={
# ssid="put SSID here"
# key_mgmt=NONE
## WEP "secured"
## WEP can be cracked within minutes. If your network is still relying on this
## encryption scheme you should seriously consider to update your network ASAP.
#network={
# key_mgmt=NONE
# wep_key0="put password here"
# wep_tx_keyidx=0
# Uncomment the country your Pi is in to activate Wifi in RaspberryPi 3 B+ and above
# For full list see: https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2
#country=GB # United Kingdom
#country=CA # Canada
#country=DE # Germany
#country=FR # France
country=US # United States
### You should not have to change the lines below #####################
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
Additional notes:
- My Raspberry Pi is connected to a 5v buck converter connected to my Ender3 power supply using the wires from the original plug that it came with.
- I plugged it into HDMI to verify that it is working. It indeed is. When I power it on, it goes through the usual Linux startup process and then I get the following message (note the absence of an address):
You may now open a web browser on your local network and navigate to any of the following addresses to access OctoPrint:
https is also available, with a self-signed certificate.
- When I connected it directly to my computer via ethernet, it did generate an address, but when I tried to connect to it via my personal computer, it timed out every time.
