Raspberry pi module model G
Not able to get camera stream working on octopi.
I tested that the camera is working properly on the raspberry itself, I am able to take and see pictures from it. I enabled the camera on the pi but I only have the legacy option. When legacy is disable, nothing is detected with vcgencmd get_camera but I am able to take picture. When legacy is enable I see the cam detected and can still take pictures. I tried to run haproxy and looked at the file but did not change anything. I ran the upgrade and update command. I changed the octopi.txt file for my camea. I changed the URL adress for the stream and snapshot to different things. To be honest maybe I tried too many things I've been looking at solution for 3 days now.
octoprint-systeminfo-20230405011923.zip (93.5 KB)
I attached the system info downloaded from octoprint, not sure if it's the best way.
