I recently updated my raspberry Pi to the latest Octopi 0.18.0 with the included Octoprint (1.5.2) since I had a very old version before. But when I log in Octoprint it says:
"There are updates available for the following components:
- OctoPrint: 1.6.1
- File Check Plugin: 2021.2.23
- Firmware Check Plugin: 2021.2.4"
But when I try to update directly from Octoprint I only get the error:
"The update could not be started. Is it already active? Please consult octoprint.log for details."
So to conclude the problem, It is not possible to update from Octoprint and also not possible to install plugins.
- I have tried to change the power-supply to a more powerful one since I got the 5V under-voltage error message also. The under-voltage message have disappeared but I still cannot update.
- I have also taped the 5V pin from the Pi to the printer after reading there is known issues with back-powering on the Creality printers.
- I have also tried the most obvious solutions as to reboot the Pi, change browser, safe-mode.
Yes.
No.
octoprint.log (1.0 MB)
serial.log (148 Bytes)
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.212 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 915722240
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.throttle_state: 0x50005
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.2
Everything works flawlessly now and I could both update and installing plugins. Thanks for the help.
