I have been using Octoprint for a long time but when i tried to install Klipper today, and i had to connect to the Raspberry Pi via SSH, the terminal gave an error message
me: ssh pi@octopi.local
pi@octopi.local: Permission denied (publickey).
I tried different addresses and tried using PUTTY, i also tried putting the API key after the command.
I'm using a Raspberry Pi 3b+ connected to a Elegoo Neptune 2s, the pi is connected via Ethernet.
