I set up a new version of Octoprint on a Windows Server. Everything looks like it's running ok. But it completely freezes when I attempt to connect to it. I've tried http://127.0.0.1:5000/ from the server itself and ip:5000 from a remote computer and neither work. Is there something wrong that I've done in the setup?
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\System32>C:\OctoPrint\venv\Scripts\octoprint.exe serve
2019-06-04 16:01:17,076 - octoprint.startup - INFO - ***************************
2019-06-04 16:01:17,079 - octoprint.startup - INFO - Starting OctoPrint 1.3.11
2019-06-04 16:01:17,081 - octoprint.startup - INFO - Starting in SAFE MODE. Thir
d party plugins will be disabled!
2019-06-04 16:01:17,082 - octoprint.startup - INFO - Reason for safe mode: probl
em during last startup
2019-06-04 16:01:17,082 - octoprint.startup - INFO - ***************************
2019-06-04 16:01:17,395 - octoprint.plugin.core - INFO - Loading plugins from c:
\octoprint\venv\lib\site-packages\octoprint\plugins, C:\Users\Administrator.BT-W
S\AppData\Roaming\OctoPrint\plugins and installed plugin packages...
2019-06-04 16:01:18,779 - octoprint.plugin.core - INFO - Plugin Pi Support Plugi
n did not pass check, not loading.
2019-06-04 16:01:18,951 - octoprint.plugins.octoprint.plugins.discovery - INFO -
 pybonjour is not installed, Zeroconf Discovery won't be available
2019-06-04 16:01:18,961 - octoprint.plugin.core - INFO - Found 14 plugin(s) prov
iding 14 mixin implementations, 22 hook handlers
2019-06-04 16:01:19,042 - octoprint.server.heartbeat - INFO - Starting server he
artbeat, 900.0s interval
2019-06-04 16:01:19,273 - octoprint.server - INFO - Intermediary server started
2019-06-04 16:01:19,273 - octoprint.plugin.core - INFO - Loading plugins from c:
2019-06-04 16:01:19,286 - octoprint.plugin.core - INFO - Plugin Pi Support Plugi
2019-06-04 16:01:19,354 - octoprint.plugin.core - INFO - Found 14 plugin(s) prov
2019-06-04 16:01:19,381 - octoprint.filemanager.storage - INFO - Initializing th
e file metadata for C:\Users\Administrator.BT-WS\AppData\Roaming\OctoPrint\uploa
ds...
2019-06-04 16:01:19,384 - octoprint.filemanager.storage - INFO - ... file metada
ta for C:\Users\Administrator.BT-WS\AppData\Roaming\OctoPrint\uploads initialize
d successfully.
2019-06-04 16:01:20,332 - octoprint.util.pip - INFO - Using "c:\octoprint\venv\s
cripts\python.exe -m pip" as command to invoke pip
2019-06-04 16:01:21,424 - octoprint.util.pip - INFO - Version of pip is 19.1.1
2019-06-04 16:01:21,426 - octoprint.util.pip - INFO - pip installs to c:\octopri
nt\venv\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual e
nv -> yes
2019-06-04 16:01:21,427 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-06-04 16:01:21,430 - octoprint.plugin.core - INFO - Initialized 14 plugin i
mplementation(s)
2019-06-04 16:01:21,434 - octoprint.plugin.core - INFO - 14 plugin(s) registered
 with the system:
|  Action Command Prompt Support (bundled) = c:\octoprint\venv\lib\site-packages
\octoprint\plugins\action_command_prompt
|  Announcement Plugin (bundled) = c:\octoprint\venv\lib\site-packages\octoprint
\plugins\announcements
|  Anonymous Usage Tracking (bundled) = c:\octoprint\venv\lib\site-packages\octo
print\plugins\tracking
|  Application Keys Plugin (bundled) = c:\octoprint\venv\lib\site-packages\octop
rint\plugins\appkeys
|  Backup & Restore (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\pl
ugins\backup
|  Core Wizard (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins
\corewizard
|  Discovery (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\d
iscovery
|  Error Tracking (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plug
ins\errortracking
|  Force Login (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins
\forcelogin
|  Logging (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\log
ging
|  Plugin Manager (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plug
ins\pluginmanager
|  Printer Safety Check (bundled) = c:\octoprint\venv\lib\site-packages\octoprin
t\plugins\printer_safety_check
|  Software Update (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plu
gins\softwareupdate
|  Virtual Printer (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plu
gins\virtual_printer
2019-06-04 16:01:21,444 - octoprint.environment - INFO - Detected environment is
 Python 2.7.16 under Windows (win32). Details:
|  hardware:
|    cores: 4
|    freq: 3700.0
|    ram: 8461086720
|  os:
|    platform: win32
|  python:
|    pip: 19.1.1
|    version: 2.7.16
|    virtualenv: c:\octoprint\venv
2019-06-04 16:01:21,450 - octoprint.server - INFO - Reset webasset folder C:\Use
rs\Administrator.BT-WS\AppData\Roaming\OctoPrint\generated\webassets...
2019-06-04 16:01:21,451 - octoprint.server - INFO - Reset webasset folder C:\Use
rs\Administrator.BT-WS\AppData\Roaming\OctoPrint\generated\.webassets-cache...
2019-06-04 16:01:21,967 - octoprint.server - INFO - Shutting down intermediary s
erver...
2019-06-04 16:01:22,275 - octoprint.server - INFO - Intermediary server shut dow
n
2019-06-04 16:01:22,279 - octoprint.events - INFO - Processing startup event, th
is is our first event
2019-06-04 16:01:22,280 - octoprint.events - INFO - Adding 0 events to queue tha
t were held back before startup event
2019-06-04 16:01:22,286 - octoprint.filemanager - INFO - Adding backlog items fr
om all storage types to analysis queue...
2019-06-04 16:01:22,292 - octoprint.filemanager - INFO - Added 0 items from stor
age type "local" to analysis queue
2019-06-04 16:01:22,292 - octoprint.server.util.watchdog - INFO - Running initia
l scan on watched folder...
2019-06-04 16:01:22,296 - octoprint.server.util.watchdog - INFO - ... initial sc
an done.
2019-06-04 16:01:22,308 - octoprint.plugins.discovery - INFO - Registered OctoPr
int instance on BT-WS for SSDP
2019-06-04 16:01:22,335 - octoprint.server - INFO - Listening on http://0.0.0.0:
5000 and http://[::]:5000
