Hello all,
First post here, probably wont be the last lol.
Well I have a problem with my printer not extruding during printing. It started after 2 days after setting up octoprint to control my CR10S. I was able to print without issue for numerous prints, and then it just stopped extruding.
-The extruder drive gear turns and retracts but no filiment extrudes.
- Filament extrudes when directed to manually through octoprint or the printers control even immediately after failing to extrude like the above.
- Tested varying degrees of pressure on the filament idler with the extruder just kicking and still failing to act properly.
- Performed cold pulls as well as completely clearing the nozzle. Eventually replaced the nozzle. no difference noted.
-Updated to the most current TH3D firmware with no difference coming from it. - Printing works off and on with working to not working times currently being 3 days on 2 weeks off.
- Installed stepper driver buffers on x, y, and extruder motors, with no difference noted to performance besides the higher frequency noises silencing notably.
- I'm running the stock cr10s PLA at 210c-220c with the filament almost pouring out, and hatchbox pla at 200-210c. Temperature hasnt appeared to be a cause due to by running the same file through different temps made no difference.
Below is a same of a print of mine running Hatchbox PLA at 200c at 50mm/s. No filament was extruding 5 minutes into the actual print(post preheat), so the bottom section is after i cancelled. The settings ran on this print I have run on 5 prints with this PLA in the past 4 days, but now it doesnt work, and this is the cycle I have been experiencing for months.
PLEASE HAAAAAALPPP.
Send: N424 G1 X142.786 Y101.309 E24.27331*86
Recv: ok
Send: N425 G1 X145.171 Y101.828 E24.35449*93
Recv: ok
Send: N426 G1 X147.668 Y102.299 E24.439*81
Recv: ok
Send: N427 G1 X150.136 Y102.692 E24.52213*92
Recv: ok
Send: N428 G1 X152.599 Y103.014 E24.60474*95
Recv: ok
Send: N429 G1 X155.104 Y103.268 E24.68849*90
Recv: ok
Send: N430 G1 X158.495 Y103.501 E24.80154*89
Recv: ok
Send: N431 G1 X158.778 Y103.515 E24.81096*83
Recv: ok
Send: N432 G1 X161.425 Y103.611 E24.89906*94
Recv: ok
Send: N433 G1 X163.314 Y103.631 E24.96189*91
Recv: ok
Send: N434 G1 X218.317 Y103.637 E26.7913*103
Recv: ok
Send: N435 G1 X227.724 Y103.632 E27.10418*90
Recv: ok
Send: N436 G1 X230.434 Y103.592 E27.19432*85
Recv: ok
Send: N437 G1 X231.218 Y103.573 E27.2204*107
Recv: ok
Send: N438 G1 X231.528 Y103.57 E27.23072*99
Recv: ok
Send: N439 G1 X232.068 Y103.572 E27.24868*86
Recv: ok
Send: N440 G1 X232.625 Y103.568 E27.2672*109
Recv: ok
Send: N441 G1 X232.826 Y103.569 E27.27389*86
Recv: ok
Send: N442 G1 X233.194 Y103.573 E27.28613*86
Recv: ok
Send: N443 G1 X234.139 Y103.622 E27.3176*109
Recv: ok
Send: N444 G1 X234.723 Y103.677 E27.33711*83
Recv: ok
Send: N445 G1 X234.902 Y103.696 E27.3431*98
Recv: ok
Send: N446 G1 X235.256 Y103.735 E27.35494*88
Recv: T:200.07 /200.00 B:60.24 /60.00 @:75 B@:0
Recv: ok
Send: N447 G1 X235.453 Y103.758 E27.36154*91
Recv: ok
Send: N448 G1 X235.907 Y103.816 E27.37676*91
Recv: ok
Send: N449 G1 X236.848 Y103.976 E27.40851*95
Recv: ok
Send: N450 G1 X238.098 Y104.319 E27.45162*84
Recv: ok
Send: N451 G1 X238.52 Y104.461 E27.46643*108
Recv: ok
Send: N452 G1 X238.867 Y104.584 E27.47868*93
Recv: ok
Send: N453 G1 X239.162 Y104.694 E27.48915*87
Recv: ok
Send: N454 G1 X240.042 Y105.065 E27.52091*90
Recv: T:199.74 /200.00 B:60.09 /60.00 @:86 B@:0
Recv: echo:busy: processing
Recv: ok
Send: N455 G1 X240.609 Y105.352 E27.54205*92
Recv: T:199.91 /200.00 B:59.88 /60.00 @:80 B@:127
Recv: ok
Send: N456 G1 X240.897 Y105.508 E27.55294*86
Recv: ok
Send: N457 G1 X241.231 Y105.697 E27.56571*90
Recv: ok
Send: N458 G1 X241.934 Y106.109 E27.59281*95
Recv: ok
Send: N459 G1 X242.737 Y106.625 E27.62455*94
Recv: ok
Send: N460 G1 X243.494 Y107.208 E27.65633*80
Recv: ok
Send: N461 G1 X244.199 Y107.851 E27.68807*92
Recv: ok
Send: N462 G1 X244.997 Y108.729 E27.72753*83
Recv: ok
Send: N463 G1 X245.176 Y108.948 E27.73694*86
Recv: ok
Send: N464 G1 X245.466 Y109.319 E27.7526*99
Recv: ok
Send: N465 G1 X246.011 Y110.045 E27.78279*82
Recv: ok
Send: N466 G1 X246.119 Y110.192 E27.78886*89
Recv: ok
Send: N467 G1 X246.519 Y110.743 E27.81151*83
--- too many lines to buffer, cut off ---
Recv: T:200.10 /200.00 B:60.10 /60.00 @:74 B@:0
Recv: T:200.03 /200.00 B:59.78 /60.00 @:76 B@:127
Recv: T:199.94 /200.00 B:59.91 /60.00 @:79 B@:127
Recv: T:199.97 /200.00 B:60.13 /60.00 @:79 B@:0
Recv: T:200.14 /200.00 B:60.17 /60.00 @:73 B@:0
Recv: ok
Recv: ok
Recv: ok
Changing monitoring state from "Cancelling" to "Operational"
