login as: pi
pi@192.168.1.42's password:
Linux octopi 5.4.79-v7l+ #1373 SMP Mon Nov 23 13:27:40 GMT 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Apr 24 12:55:20 2021
File "", line 1, in
ModuleNotFoundError: No module named 'octoprint'
Access OctoPrint from a web browser on your network by navigating to any of:
http://octopi.local
http://192.168.1.42
https is also available, with a self-signed certificate.
This image comes without a desktop environment installed because it's not
required for running OctoPrint. If you want a desktop environment you can
install it via
sudo /home/pi/scripts/install-desktop
OctoPrint version : unknown
OctoPi version : 0.18.0
pi@octopi:~ ModuleNotFoundError: No module named 'octoprint'
-bash: ModuleNotFoundError:: command not found
pi@octopi:~ ~/oprint/bin/python --version
Python 3.7.3
pi@octopi:~ ~/oprint/bin/pip install --force-reinstall --no-cache-dir octoprin t
File "/home/pi/oprint/bin/pip", line 5, in <module>
from pip._internal.cli.main import main
ModuleNotFoundError: No module named 'pip'
pi@octopi:~ sudo service octoprint restart
pi@octopi:~ ~/oprint/bin/python -m pip install --force-reinstall --no-cache-di r octoprint
/home/pi/oprint/bin/python: No module named pip
pi@octopi:~ ls ~
mjpg-streamer OctoPrint oprint scripts upgrade.py
I did use search to find out why its not working tried lot of ways and checks - nothing helps - it just stopped working.
running on PI 4 B. did try to reinstall PIP - did not help. it just stopped.
in log my camera stopped working - but that`s not should be an issue that octoprint starts.
all systems are updated to latest versions and it was running for 12h
If it isn't, the question is why. Take a look into ~/.octoprint/logs/octoprint.log , there might be an error logged in there that helps to determine what's wrong.
You might also want to try if you can restart the server (if no obvious error is visible): sudo service octoprint restart .
If all that doesn't help to trouble shoot the issue, you can seek support on the OctoPrint Community Forum. Please provide your OctoPi and OctoPrint versions as well as your octoprint.log and explain what you already tried and observed as detailed as possible.
With a camera, make sure it didn't fill the filesystem full. Ssh in and do df -h. If any are at 100% then the file system is full and octoprint will not start. Also, use the link on the word logs in the forum to get the logs needed to troubleshoot. Otherwise, anything is just a guess
OK guys, I`m gonna install it on new sd card Class 10 64GB.
there is any log files or commands which i need to run extra to get more info if this type again happens???
who can advise something?
I have 1 more question guy`s
how I can backup already configured image?
and then restore it?
i have a idea of make config fully and just backup it - and when it happens again I just can restore it
