Is there a way (maybe plugin?) that can detect and alert when the print has become loose from the plate and is just printing in mid air?
This would be using the pi camera that is connected to the pi that is running octoPrint
I have a feeling this might not be possible due to the complexity of the problem
Researching online
N/A
Complete Logs
N/A
Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.4
Octopi 1.4.2
