Hello
Objects are not printed at the center of the bed of my 3Dprinter !? all object begins to print to the right upper corner of the bed... (when I look my printer from up)
I use a Makerbot Replicator 2 with the GPX plugIn and a printer profile done with CURA
I tried to modify de Center-offset parameters in .INI file of the Printer Profil -> Doesn't work
Last Octoprint Version (at 13/12/2018), Printer version is a MakerBot Replicator 2
Do you have any advices to solve this issue ?
regards
Yann
