Octo Everywhere can´t connect to Octoprint on Win 10
After installing "Octo Everywhere" no Connection form outside
Hello,
mabee one of you had the same troubles with this plug in i´d like to use.
Installes Octoprint on my Win10 PC, evrything is working fine, via LAN,
and if i´m not around, i´d like to see what´s going on. So I installed Octo everywhere,
created my account, my printer is online, but when I click connect - timeout -
on the console it shows this error message:
2021-04-05 20:13:15,357 - octoprint.plugins.octoeverywhere - ERROR - Failed to make local request. HTTPConnectionPool(host='127.0.0.1', port=5000): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x000001CAA505F2E0>: Failed to establish a new connection: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte')) for http://127.0.0.1:5000/
2021-04-05 20:13:15,357 - octoprint.plugins.octoeverywhere - ERROR - Session reported an error [wss://starport.octoeverywhere.com/octoclientws[1]], closing the websocket. Backoff time sec: 1
2021-04-05 20:13:15,357 - octoprint.plugins.octoeverywhere - INFO - Closing all open proxy sockets (0)
2021-04-05 20:13:15,379 - octoprint.plugins.octoeverywhere - INFO - Service websocket closed.
2021-04-05 20:13:15,379 - octoprint.plugins.octoeverywhere - INFO - Disconnected from OctoEverywhere, server con wss://starport.octoeverywhere.com/octoclientws[1]
Is there any port in Win i´ve to open?
Maybee someone can help me ???
Thanks in advance.
System: i5/Win10/8GB RAM/python 3.9.4/latest octoprint
I get the same issue on my windows 7 PC running the same way. Did you use Chris Riley's Howto?
(Octoprint On Windows - Print Farm Server - Chris's Basement - YouTube)
I get a "target machine actively refused" message.
Hi! Yes i did use the Chris Riley´s Howto.
I also tried newer versions of python - but still the same.
i still have no solution.
