When I go to connect Octopi will not connect
I am at a loss as to what to do.
N/A
I don't know what you're looking for.
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... *as much data as possible
latest versions - SunLu S8 Factory firmware, Chrome browser, Window 10,
copy of Terminal follows:
Changing monitoring state from "Offline" to "Detecting serial connection"
Performing autodetection with 2 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyS0@115200
Trying port /dev/ttyUSB0, baudrate 115200
Connecting to port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0xaab12bf0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Handshake attempt #2 with timeout 2.0s
Handshake attempt #3 with timeout 2.0s
Trying port /dev/ttyS0, baudrate 115200
Connecting to port /dev/ttyS0, baudrate 115200
Unexpected error while connecting to serial port /dev/ttyS0, baudrate 115200 from hook default: SerialException: '[Errno 13] could not open port /dev/ttyS0: [Errno 13] Permission denied: '/dev/ttyS0'' @ comm.py:_open_serial:3699
Could not open port /dev/ttyS0, baudrate 115200, skipping
Changing monitoring state from "Detecting serial connection" to "Error"
Changing monitoring state from "Error" to "Offline after error"
Connected to: Serial<id=0xb2ae2270, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Recv: ùNpp4b6\x16\x17JpCF6\x93\x88B\x90´%\x00g~´%\x92Iè¸ává\x12b\x9bpyÐX\x92XáB\x13\x13ðnø5\x08\x00>\x93]\x93'\x97ð-Qþ\x17\x12\x14ùN\x93\x136\x17zS.\x1bðS\x10'\x970^\xffB\x94\x98\x17J\x92%\x18\x10\x18\x17J´c\x12ðeÁAháYp|:M\x1bP\x13:\x97P*l\x8bp|\x10(\x18]öráJ\x94B\x90@á\x12\x93H\x17X&váB¸BJ\x988J\x90(C\x92B\xffZBtp$fP\x1fN\x17üaÉ<p|\x10(\x1aþB\x9eB\xffB\x8eBs\x14¿HBpt8n\x08åMa>`eÉbváB\x9cJü\x98 \x948%xCrñ
WARNThe received line contains at least one null byte character at position 20, this hints at some data corruption going on
Connected to: Serial<id=0xab24eed0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
