WRITE HERE After loading OctoPrint was able to load the octopi.local page, but after trying to install OctoPrint deploy, I get this "The OctoPrint server is currently not running"
WRITE HERE I tried to get my log from SSH but it says pi@octopi : ~ $ ~/.octoprint/logs/octoprint.log
It's a script to setup multiple instances with your input and configuration. So surely you must have done something while trying to do this.
You've tried to run (execute) the log file. It's not a runnable program.... If you would like to get the file, you will need to either use a file transfer thing such as FileZilla or WinSCP. If you would like to read this file you can print it to the console by using cat ~/.octoprint/logs/octoprint.log.
Hi Thanks for helping me with some info, I am fairly new at this so please forgive me. I was stupid and after running Octoprint Deploy, I didn’t type in the correct set of numbers for my new local address, this did not allo me me to connect to the Octoprint server. It’s up and running now.
