Octo print starts to fast
Hello, My ender5 starts the print right away and the temps are not even war. Now it's been fine until tonight, I don't think I did anything to my setting.
1.4.0 version
Chrome or Safari
mac
I've been printing with this for 5 weeks with really no problem like this please help
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: start
Recv: echo:Marlin 1.1.8
Recv:
Recv: echo: Last Updated: 2019-01-11 | Author: (Ender-5)
Recv: echo:Compiled: May 30 2019
Recv: echo: Free Memory: 9448  PlannerBufferBytes: 1232
Recv: echo:SD init fail
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin Creality 3D SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-5 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:0
Recv: Cap:Z_PROBE:0
Recv: Cap:LEVELING_DATA:0
Recv: Cap:BUILD_PERCENT:0
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: M21
Recv: ok
Send: M155 S2
Recv: ok
Recv:  T:20.90 /0.00 B:19.77 /0.00 @:0 B@:0
Recv:  T:20.90 /0.00 B:19.73 /0.00 @:0 B@:0
Recv:  T:20.94 /0.00 B:19.57 /0.00 @:0 B@:0
Recv:  T:20.74 /0.00 B:19.65 /0.00 @:0 B@:0
Recv:  T:20.82 /0.00 B:19.73 /0.00 @:0 B@:0
Recv:  T:20.82 /0.00 B:19.57 /0.00 @:0 B@:0
Recv:  T:20.90 /0.00 B:19.65 /0.00 @:0 B@:0
Recv:  T:20.98 /0.00 B:19.57 /0.00 @:0 B@:0
Recv:  T:20.82 /0.00 B:19.65 /0.00 @:0 B@:0
Recv:  T:20.74 /0.00 B:19.49 /0.00 @:0 B@:0
Recv:  T:20.90 /0.00 B:19.61 /0.00 @:0 B@:0
Recv:  T:20.82 /0.00 B:19.53 /0.00 @:0 B@:0
Recv:  T:20.74 /0.00 B:19.45 /0.00 @:0 B@:0
Recv:  T:20.70 /0.00 B:19.57 /0.00 @:0 B@:0
Recv:  T:20.90 /0.00 B:19.41 /0.00 @:0 B@:0
Recv:  T:20.98 /0.00 B:19.37 /0.00 @:0 B@:0
Recv:  T:20.74 /0.00 B:19.57 /0.00 @:0 B@:0
Recv:  T:20.86 /0.00 B:19.41 /0.00 @:0 B@:0
Recv:  T:20.82 /0.00 B:19.41 /0.00 @:0 B@:0
Recv:  T:20.66 /0.00 B:19.37 /0.00 @:0 B@:0
Recv:  T:20.70 /0.00 B:19.41 /0.00 @:0 B@:0
Recv:  T:20.78 /0.00 B:19.37 /0.00 @:0 B@:0
Recv:  T:20.78 /0.00 B:19.41 /0.00 @:0 B@:0
Recv:  T:20.78 /0.00 B:19.45 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.41 /0.00 @:0 B@:0
Recv:  T:20.74 /0.00 B:19.37 /0.00 @:0 B@:0
Recv:  T:20.70 /0.00 B:19.37 /0.00 @:0 B@:0
Recv:  T:20.82 /0.00 B:19.37 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.37 /0.00 @:0 B@:0
Changing monitoring state from "Operational" to "Starting"
Send: N2 M114*37
Recv: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv: ok
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 M105*38
Recv: ok T:20.62 /0.00 B:19.37 /0.00 @:0 B@:0
Send: N2 M105*37
Send: N3 M82*26
Recv: ok
Send: N4 M201 X500.00 Y500.00 Z100.00 E5000.00*14
Recv: ok
Send: N5 M203 X500.00 Y500.00 Z10.00 E50.00*61
Recv: ok
Send: N6 M204 P500.00 R1000.00 T500.00*122
Recv: Setting Print Acceleration: 500.00
Recv: Setting Retract Acceleration: 1000.00
Recv: Setting Travel Acceleration: 500.00
Recv: ok
Send: N7 M205 X8.00 Y8.00 Z0.40 E5.00*60
Recv: ok
Send: N8 M220 S100*105
Recv: ok
Send: N9 M221 S100*105
Recv: ok
Send: N10 G90 :use Absolute coordinates*30
Recv: ok
Send: N11 G28*35
Recv:  T:20.62 /0.00 B:19.34 /0.00 @:0 B@:0
Recv: echo:busy: processing
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
Changing monitoring state from "Printing" to "Cancelling"
Recv: ok
Send: N12 G92 E0*116
Recv: ok
Send: N13 M108*24
Recv: ok
Send: N14 M113 S2*84
Recv: ok
Send: N15 M84*43
Recv: ok
Send: N16 M104 T0 S0*22
Recv: ok
Send: N17 M140 S0*83
Recv: ok
Send: N18 M106 S0*94
Recv: ok
Changing monitoring state from "Cancelling" to "Operational"
Recv:  T:20.66 /0.00 B:19.34 /0.00 @:0 B@:0
Recv:  T:20.70 /0.00 B:19.34 /0.00 @:0 B@:0
Recv:  T:20.70 /0.00 B:19.22 /0.00 @:0 B@:0
Recv:  T:20.66 /0.00 B:19.30 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.30 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.18 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.22 /0.00 @:0 B@:0
Recv:  T:20.66 /0.00 B:19.22 /0.00 @:0 B@:0
Recv:  T:20.66 /0.00 B:19.18 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.14 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.06 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.10 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.02 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.98 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:19.26 /0.00 @:0 B@:0
Recv:  T:20.66 /0.00 B:19.06 /0.00 @:0 B@:0
Recv:  T:20.66 /0.00 B:19.02 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.91 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.95 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.87 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.79 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.83 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.75 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.71 /0.00 @:0 B@:0
Recv:  T:20.66 /0.00 B:18.75 /0.00 @:0 B@:0
Recv:  T:20.62 /0.00 B:18.67 /0.00 @:0 B@:0
Hi, and welcome!
First, if you attach long log files, it's best that you paste them as links. It get messy in a hurry in here if the posts are really long.
Second, does your printer warm up if you try from the printer itself?
Good morning Brad, I’m working on it right now and somehow I reloaded the printer profile in octoprint and it came back online within the last 10 minutes and I’m running a test cube right now but that was kind of weird I don’t know how it happened but thank you very much I’m glad that you reached out to me this morning and at this time because it looks like it’s working just fine again.
There are no temperature command in this GCODE up until the one injected by you clicking cancel. You need to make sure your slicer actually tells your printer to heat up, that ain't the job of OctoPrint but of your sliced files.
