Octo4a Handshake fails
The handshake fails in the Terminal window
Changed serial driver from default CH341 to others. No change
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: unknown
env.hardware.freq: unknown
env.hardware.ram: unknown
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.python.pip: 22.3.1
env.python.version: 3.10.10
env.python.virtualenv: False
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.2
systeminfo.generated: 2023-08-13T21:40:27Z
systeminfo.generator: zipapi
The connection on the Octo4a seems fine. It shows Octoprint running and shows the connection to the printer - dev/bus/usb/001/004. The camera shows the printer via :5001/mjpeg in my browser. But, when I select Connect, it gives me this for each of the baud rates:
2023-08-13 21:10:38,944 - Enabling serial logging
2023-08-13 21:10:40,857 - Trying port /dev/ttyOcto4a, baudrate 19200
2023-08-13 21:10:40,864 - Handshake attempt #1 with timeout 5.0s
2023-08-13 21:10:40,868 - Send: N0 M110 N0125
2023-08-13 21:10:45,874 - Handshake attempt #2 with timeout 5.0s
2023-08-13 21:10:45,881 - Send: N0 M110 N0
125
2023-08-13 21:10:50,887 - Handshake attempt #3 with timeout 5.0s
2023-08-13 21:10:50,897 - Send: N0 M110 N0125
2023-08-13 21:10:55,902 - Trying port /dev/ttyOcto4a, baudrate 9600
2023-08-13 21:10:55,909 - Handshake attempt #1 with timeout 5.0s
2023-08-13 21:10:55,913 - Send: N0 M110 N0
125
2023-08-13 21:11:00,920 - Handshake attempt #2 with timeout 5.0s
2023-08-13 21:11:00,931 - Send: N0 M110 N0125
2023-08-13 21:11:05,934 - Handshake attempt #3 with timeout 5.0s
2023-08-13 21:11:05,943 - Send: N0 M110 N0
125
2023-08-13 21:11:10,948 - Changing monitoring state from "Detecting serial connection" to "Error"
2023-08-13 21:11:10,971 - Changing monitoring state from "Error" to "Offline after error"
2023-08-13 21:11:10,983 - Connection closed, closing down monitor
This is an unusual baudrate to use. Have you tried the others/auto?
Just seen you said it was the same for each baud rate, sorry.
One important detail - what printer do you have?
I should have mentioned that - Ender 3 V2 Neo
Lot of false leads there, The printer is not connecting to the Ender3 serial port.
Assuming the ender 3 is working properly, this would appear to be pointing to a problem with the serial cable or the serial ports on either end. check the ports for any material that has become lodged in the port and replace the cable.
