Printer will leave blob/zits because the print will pause and then continue as it prints just like the video linked. Text on the terminal will say "octoprint no response from printer after (#) consecutive communication timeouts"
-changed usb wire
-looked up .D config files to change like a few vids suggested (which octo4a do not seem to have)
-Slowed my print down 20%-ish
-updated Marlin Firmware
-changed to a higher bandwith on the wifi for octo4a server (via galaxy s9)
no
no
***no response from printer after 3 consecutive communication timeouts, considering it dead. configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves. changing monitoring state from "operational" to "offline after error" connection closed, closing down monito
-ordered ahigher sync speed micro usb and possibly faster HUB adapter (3rd one) to see if it makes a difference. Also to see if there is some config file in the android phone files where I can find the config file with the "buffer_blocker" text and change it like the video suggests above (no success on finding where the config file is on the Octo4a files in phone...)
