Octodash - Unable to rotate pi touch display 2 5" on RPI 5
Pi touch display 2 5" by default is in portrait ratio, so my cli and octodash displays vertically.
I tried to rotate my screen in landscape following official Raspberry documentation without success.
https://www.raspberrypi.com/documentation/accessories/display.html#rotate-screen-without-a-desktop
I am on Pi5 with octopi 1.1.0
Here are my configuration files :
/boot/firmware/config.txt
arm_64bit=1
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=0
# Automatically load overlays for detected DSI displays
display_auto_detect=0
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
dtoverlay=vc4-kms-dsi-ili9881-5inch,swapxy
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=0
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[all]
# enable raspicam
start_x=1
gpu_mem=128
#lcd_rotate=2
/boot/firmware/cmdline.txt :
video=DSI-1:720x1280@60,rotate=90 console=serial0,115200 console=tty1 root=PARTUUID=df4ca88c-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=FR
Everything i seen on forums...
It is system issue not octoprint one
OctoPrint version 1.11.5, OctoPi version 1.1.0, Prusa Core One
WeBa @n0dr4c !
What's about removing the "#" in front of lcd_rotate=2?
Hi @Ewald_Ikemann
For lcd_rotate it seems to be an old parameter that is no more supported in my version.
I succeed to rotate cli view (used DSI-2 instead of DSI-1 in cmdline.cfg) but Octodash still is in portrait...
Okay i found the solution to rotate Octodash GUI. I had to create a file in X11 context (/usr/share/X11/xorg.conf.d/90-monitor.conf) and add these lines :
Section "Monitor"
Identifier "DSI-2"
Option "Rotate" "right"
EndSection
That's interesting, how did you determine it was DSI-2 instead of DSI-1? All the guides I've seen thus far are DSI-0 and DSI-1 and I've seen several people struggling with stuff like this recently with waveshare touch screens.
I seen a post that was talking about pi5 use an other DSI display number... I do not remember where i seen it...
