I have the OctoPi up and running with OctoPrint and I have now added a touch screen with OctoDash but can't get it to connect to OctoPrint.
I can't get past the setup screens due to it keeps saying it can't connect. I have tried restarting it. I tried to enter the API key in manually and still won't connect or go past the setup screens.
Gargoyle, try this. Uninstall the OctoDash Companion plugin (it really should be installed after OctoDash is setup and operational). Make sure that in OctoPrint's settings under API that this checkbox is enabled (restart OctoPrint if it wasn't).
rm ~/.config/octodash/config.json
sudo service getty@tty1 restart
go through the OctoDash setup again, when you get to the option to select the OctoPrint url choose to use manual method and enter http://localhost:5000/.
