Camera model Raspberry pi cam
What is the problem? octolapse show camera at 90 degrees angle, meanwhile the webcam stream is correct.
What did you already try to solve it? yes, move and change every possible settings
2020-10-08 08:19:49,277 - octolapse.settings_external - ERROR - Could not retrieve the settings file from the server! Using cached version.
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connection.py", line 160, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/util/connection.py", line 61, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request
self._validate_conn(conn)
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 978, in _validate_conn
conn.connect()
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connection.py", line 309, in connect
conn = self._new_conn()
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connection.py", line 172, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0xa069d450>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File "/home/pi/oprint/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/util/retry.py", line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /FormerLurker/Octolapse-Profiles/master/versions.json?nonce=ecc5e43aa0264595b403675e5424e3f3 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xa069d450>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/settings_external.py", line 250, in _get_versions
timeout=float(10)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/raven/breadcrumbs.py", line 341, in send
resp = real_send(self, request, *args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /FormerLurker/Octolapse-Profiles/master/versions.json?nonce=ecc5e43aa0264595b403675e5424e3f3 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xa069d450>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/settings_external.py", line 43, in get_available_profiles
profiles_dict = ExternalSettings._get_profiles_from_server(current_octolapse_version)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/settings_external.py", line 83, in _get_profiles_from_server
settings_version = ExternalSettings._get_best_settings_version(current_octolapse_version)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/settings_external.py", line 217, in _get_best_settings_version
versions = ExternalSettings._get_versions()["versions"]
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/settings_external.py", line 259, in _get_versions
raise ExternalSettingsError('profiles-retrieval-error', message, cause=e)
octoprint_octolapse.settings_external.ExternalSettingsError: profiles-retrieval-error: An error occurred while retrieving profiles from the server. - Inner Exception: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /FormerLurker/Octolapse-Profiles/master/versions.json?nonce=ecc5e43aa0264595b403675e5424e3f3 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xa069d450>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
2020-10-08 08:21:54,058 - octolapse.settings_external - ERROR - Could not retrieve the settings file from the server! Using cached version.
chunked=chunked,
conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0xb11a8270>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /FormerLurker/Octolapse-Profiles/master/versions.json?nonce=7438f5295bea43fb890526a8ba758d8a (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb11a8270>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
timeout=float(10)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /FormerLurker/Octolapse-Profiles/master/versions.json?nonce=7438f5295bea43fb890526a8ba758d8a (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb11a8270>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
octoprint_octolapse.settings_external.ExternalSettingsError: profiles-retrieval-error: An error occurred while retrieving profiles from the server. - Inner Exception: HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /FormerLurker/Octolapse-Profiles/master/versions.json?nonce=7438f5295bea43fb890526a8ba758d8a (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb11a8270>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Additional information about your setup (OctoPrint version, OctoPi version, ...)latest octoprint version!
