When starting an octolapse print I get the following error: (Please keep in mind I am extremely new to 3D printing, Octoprint, Octolapse, and g-code.
I have done quite a bit of googling around without much help and have tried the following:
- Setting Firmware settings as require explicit as well as default to absolute.
- Tried entering a G21 in the g-code from the slicer at various points including the first thing.
- Made sure my slicer isn't using a different unit of measure other than mm
- tried putting in a G21 at the beginning of the "Home Axis Gcode Script" in the printer settings in Octolapse.
- Tried dang near all the "Trigger" types most of the "Smart" triggers will say that it is starting the print but then never actually start anything. Any other trigger gives me the error about the
Complete Logs
Try again.gcode (1.1 MB)
2020-08-15 22:13:49,675 - octoprint.util.comm - INFO - Ignoring resend request for line 2 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2020-08-15 22:13:49,744 - octoprint.util.comm - INFO - Printer reports firmware name "Prusa-Firmware 3.9.0 based on Marlin"
2020-08-15 22:13:50,724 - octoprint.server.preemptive_cache - INFO - ... done in 6.01s
2020-08-15 22:13:50,724 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.local/'}
2020-08-15 22:13:50,955 - octoprint.server.preemptive_cache - INFO - ... done in 0.23s
2020-08-15 22:13:57,666 - octoprint.server.util.flask - INFO - Passively logging in user username from ::ffff:10.0.0.22
2020-08-15 22:13:57,668 - octoprint.access.users - INFO - Logged in user: username
2020-08-15 22:13:57,794 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.0.0.22
2020-08-15 22:13:58,665 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.0.0.22
2020-08-15 22:13:58,845 - octoprint.server.util.flask - INFO - Passively logging in user username from ::ffff:10.0.0.22
2020-08-15 22:13:58,846 - octoprint.access.users - INFO - Logged in user: username
2020-08-15 22:14:00,335 - octoprint.server.util.sockjs - INFO - User username logged in on the socket from client ::ffff:10.0.0.22
2020-08-15 22:14:01,087 - tornado.access - WARNING - 404 GET /plugin/octolapse/getSnapshot?file_type=thumbnail&camera_guid=354def78-9eea-409a-ad23-ee966dfff4ba&apikey=&time=1597526044223 (::ffff:10.0.0.22) 1.65ms
2020-08-15 22:14:01,094 - tornado.access - WARNING - 404 GET /plugin/octolapse/getSnapshot?file_type=snapshot&camera_guid=354def78-9eea-409a-ad23-ee966dfff4ba&apikey=&time=1597526044224 (::ffff:10.0.0.22) 1.62ms
2020-08-15 22:14:06,610 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Try_again.gcode
2020-08-15 22:14:06,611 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=200 --speed-y=200 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/Try_again.gcode
2020-08-15 22:14:08,648 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Try_again.gcode, owner: username, user: username
2020-08-15 22:14:08,661 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-08-15 22:14:08,668 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Try_again.gcode, owner: username, user: username
2020-08-15 22:14:10,199 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Try_again.gcode finished, needed 3.59s
2020-08-15 22:14:28,375 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Cancelling" ###these cancellations are me cancelling the print after getting the G21 error###
2020-08-15 22:14:28,415 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Try_again.gcode, owner: username, user: username
2020-08-15 22:14:28,436 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Printing"
2020-08-15 22:14:28,688 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Operational"
2020-08-15 22:14:33,867 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-08-15 22:14:33,878 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Try_again.gcode, owner: username, user: username
2020-08-15 22:14:37,966 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Cancelling"
2020-08-15 22:14:37,984 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Try_again.gcode, owner: username, user: username
2020-08-15 22:14:38,002 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Printing"
2020-08-15 22:14:38,032 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Operational"
2020-08-15 22:14:52,435 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-08-15 22:14:52,439 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Try_again.gcode, owner: username, user: username
2020-08-15 22:14:52,537 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-15 22:14:52,554 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-08-15 22:14:55,633 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-08-15 22:14:55,663 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Try_again.gcode, owner: username, user: username
I am running a raspberry pi4 8GB with Octolaps v0.4.0 and Octoprint v1.4.2
I am slicing with PrusaSlicer (See my gcode above)
