Since I've switched to OctoPi 1.0.0, I've noticed that my Raspberry PI HQ camera suddenly shows massive compression artefacts in the webcam stream.
I've edited the octopi.txt file to add a quality argument, but it doesn't seems to work.
The weird thing is that if I restart the webcamd manually, then the artifacts go away. But after rebooting the entire system, they are back.
Edit octopi.txt and added -r 1280x720 -f 10 -q 85, tried various quality settings with no effect, 10 looks exactly the same as 90 if I manually reboot the demon. I think the quality setting is not being taken into account.
Logs:
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1280x720 -f 10 -q 85
raspi options: -fps 10
Explicitly set USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
raspi
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
<13>Feb 24 18:31:12 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1280x720 -f 10 -q 85 -d /dev/video0
MJPG Streamer Version.: 2.0
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Done bringing up all configured video devices
octoprint-systeminfo-20230227094314.zip (16.5 KB)
Raspberry PI 4, flashed from the OctoPi 1.0.0 image, with a Raspberry PI HQ camera.
