What is the problem? The new pi 3B+ won't connect to network thru wifi or ethernet
What did you already try to solve it? First tried wifi then ethernet. I tried the whole procedure multiple times, tried two different micro sd cards (Samsung 32GB and samsung 8GB). used etcher to flash the .img file, used Notepad ++ to edit the .img file, even bought a dedicated 2.5amp power supply.
ssh pi@octopi.local
ssh: Could not resolve hostname octopi.local: No such host is known.
ifconfig wlan0
'ifconfig' is not recognized as an internal or external command,
operable program or batch file.
Ran Advanced IP Scanner>>> Doesn't show octopi
Logged into my router>> octopi doesn't show up in clients
Repeated the whole process couple of times tried wifi as well as ethernet.
octoprint version 0.17.0
raspberry pi 3B+
tried on desktop windows 10 64bit and laptop windows 10 64bit
Cannot connect monitor to the raspberry pi because my monitor has DVI connector.
I still have not connected my Ender 3 Pro to the pi yet.
I will any guidance and help. Thankyou
2020-04-29T04:00:00Z
