I have some problems with my webcam configuration.
This is what I want:
webcam off by default
two entries in the system menu (webcam on/off)
automatically start/stop webcam via eventhook when PrintStarted/PrintDone
I set the correct parameters in the /boot/octoprint.txt for the Logitech C270
** camera_usb_options="-r 1280x720 -f 30"
I set up the two action commands from the Cookbook: System-Commands
** But there is a note: "...may not work correctly with OctoPi..."
** Confirmed! This does not work
Same for the eventhook - not tried yet, but same note!
So what can I do to get these system actions and events working on OctoPi?
Hi!
Actually the webcam is managed by FFMPEG that delivers the stream or snapshots to the Pi's IP. The Timelap plugins of OctoPrint tell FFMPEG to get images to create the video sequence.
AFAIK there is no option within FFMPEG to mute the camera, so it stays on as long it's plugged in. FFMPEG documentation
This would be the command that you'd run in Ubuntu to disable autostart but to leave the entry in place for later controlling it: sudo update-rc.d webcamd disable. Researching a little more, I'm pretty sure that Raspbian uses this mechanism, too. In theory, it would update those lines at the top in the ### BEGIN INIT INFO section.
Just a note for everyone else: if you like the idea of programmatically toggling the webcam on/off as needed (with the option of being off on startup), this is a useful thread.
