Raspberry Pi camera V2
The quality of the camera is really low,
this is the image quality i'm getting when just plugging into the pi via ribbion cable
What I tried to do is change the octopi.txt file to
OctoPrint version : 1.5.3
OctoPi version : 0.17.0
### Configure which camera to use
# Available options are:
# - auto: tries first usb webcam, if that's not available tries raspi cam
# - usb: only tries usb webcam
# - raspi: only tries raspi cam
# Defaults to auto
camera="raspi"
camera_raspi_options="-x 1920 -y 1080 -fps 10"
### Additional options to supply to MJPG Streamer for the USB camera
# See https://faq.octoprint.org/mjpg-streamer-config for available options
# Defaults to a resolution of 640x480 px and a framerate of 10 fps
#camera_usb_options="-r 1920x1080 -f 30"
### Additional webcam devices known to cause problems with -f
# Apparently there a some devices out there that with the current
# mjpg_streamer release do not support the -f parameter (for specifying
# the capturing framerate) and will just refuse to output an image if it
# is supplied.
# The webcam daemon will detect those devices by their USB Vendor and Product
# ID and remove the -f parameter from the options provided to mjpg_streamer.
# By default, this is done for the following devices:
# Logitech C170 (046d:082b)
# GEMBIRD (1908:2310)
# Genius F100 (0458:708c)
# Cubeternet GL-UPC822 UVC WebCam (1e4e:0102)
# Using the following option it is possible to add additional devices. If
# your webcam happens to show above symptoms, try determining your cam's
# vendor and product id via lsusb, activating the line below by removing # an$
# adding it, e.g. for two broken cameras "aabb:ccdd" and "aabb:eeff"
# additional_brokenfps_usb_devices=("aabb:ccdd" "aabb:eeff")
# If this fixes your problem, please report it back so we can include the dev$
# out of the box: https://github.com/guysoft/OctoPi/issues
#additional_brokenfps_usb_devices=()
### Additional options to supply to MJPG Streamer for the RasPi Cam
# Defaults to 10fps
#camera_raspi_options="-fps 10"
### Configuration of camera HTTP output
# Usually you should NOT need to change this at all! Only touch if you
# know what you are doing and what the parameters mean.
# Below settings are used in the mjpg-streamer call like this:
# -o "output_http.so -w $camera_http_webroot $camera_http_options"
# Current working directory is the mjpg-streamer base directory.
#camera_http_webroot="./www-octopi"
#camera_http_options="-n"
After this I'm still getting the same quality
Please run journalctl -u webcamd and see if the log is complaining of anything, and also post the output here.
pi@3DPrinter:~ $ journalctl -u webcamd
-- Logs begin at Thu 2021-01-28 14:30:18 MST, end at Thu 2021-01-28 16:48:44 M
Jan 28 14:30:21 3DPrinter systemd[1]: Starting the OctoPi webcam daemon with t
Jan 28 14:30:21 3DPrinter webcamd[304]: Starting up webcamDaemon...
Jan 28 14:30:21 3DPrinter webcamd[304]: --- Configuration: -------------------
Jan 28 14:30:21 3DPrinter webcamd[304]: cfg_file: /boot/octopi.txt
Jan 28 14:30:21 3DPrinter webcamd[304]: camera: raspi
Jan 28 14:30:21 3DPrinter webcamd[304]: usb options: -r 640x480 -f 10
Jan 28 14:30:21 3DPrinter webcamd[304]: raspi options: -x 1640 -y 1232 -fps 10
Jan 28 14:30:21 3DPrinter webcamd[304]: http options: -w ./www-octopi -n
Jan 28 14:30:21 3DPrinter webcamd[304]: Explicitly USB device:
Jan 28 14:30:21 3DPrinter webcamd[304]: --------------------------------------
Jan 28 14:30:22 3DPrinter webcamd[304]: Found video devices:
Jan 28 14:30:22 3DPrinter webcamd[304]: /dev/video0
Jan 28 14:30:22 3DPrinter webcamd[304]: /dev/video10
Jan 28 14:30:22 3DPrinter webcamd[304]: /dev/video11
Jan 28 14:30:22 3DPrinter webcamd[304]: /dev/video12
Jan 28 14:30:22 3DPrinter webcamd[304]: raspi
Jan 28 14:30:22 3DPrinter webcamd[304]: config file='/boot/octopi.txt':Start M
Jan 28 14:30:22 3DPrinter webcamd[304]: <13>Jan 28 14:30:22 root: Starting Ras
Jan 28 14:30:22 3DPrinter webcamd[304]: Running ./mjpg_streamer -o output_http
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: starting ap
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: MJPG Stream
Jan 28 14:30:22 3DPrinter webcamd[304]: MJPG Streamer Version: git rev: 501f63
Jan 28 14:30:22 3DPrinter webcamd[304]: i: fps.............: 10
Jan 28 14:30:22 3DPrinter webcamd[304]: i: resolution........: 1640 x 1232
Jan 28 14:30:22 3DPrinter webcamd[304]: i: camera parameters..............:
Jan 28 14:30:22 3DPrinter webcamd[304]: Sharpness 0, Contrast 0, Brightness 50
Jan 28 14:30:22 3DPrinter webcamd[304]: Saturation 0, ISO 0, Video Stabilisati
Jan 28 14:30:22 3DPrinter webcamd[304]: Exposure Mode 'auto', AWB Mode 'auto',
Jan 28 14:30:22 3DPrinter webcamd[304]: Metering Mode 'average', Colour Effect
Jan 28 14:30:22 3DPrinter webcamd[304]: Rotation 0, hflip No, vflip No
Jan 28 14:30:22 3DPrinter webcamd[304]: ROI x 0.000000, y 0.000000, w 1.000000
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: fps........
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: resolution.
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: camera para
Jan 28 14:30:22 3DPrinter webcamd[304]: o: www-folder-path......: ./www-octop
Jan 28 14:30:22 3DPrinter webcamd[304]: o: HTTP TCP port........: 8080
Jan 28 14:30:22 3DPrinter webcamd[304]: o: HTTP Listen Address..: (null)
Jan 28 14:30:22 3DPrinter webcamd[304]: o: username:password....: disabled
Jan 28 14:30:22 3DPrinter webcamd[304]: o: commands.............: disabled
Jan 28 14:30:22 3DPrinter webcamd[304]: i: Starting Camera
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: www-folder-
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: HTTP TCP po
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: HTTP Listen
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: username:pa
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: commands...
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: starting in
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: starting ou
Jan 28 14:30:22 3DPrinter mjpg_streamer[399]: MJPG-streamer [399]: Starting Ca
Jan 28 14:30:22 3DPrinter webcamd[304]: Encoder Buffer Size 81920
Jan 28 14:31:02 3DPrinter webcamd[304]: Done bring up all configured video dev
Jan 28 14:31:02 3DPrinter webcamd[304]: Goodbye...
Jan 28 14:31:02 3DPrinter systemd[1]: Started the OctoPi webcam daemon with th
lines 1-53/53 (END)
