Octopi.local can't be found.
I downloaded Raspberry Pi Imager and installed it on my windows 10 pc. I run it choosing Octopi OS I do cntrl+shift+x I enter the SSID of my wifi and it's password plus my location US. I choose write to the SD Card(which I have formatted) The imager write to the SD card and verifies and completes. I then check the file octopi-wpa-supplicant.txt and nothing has been filled in it's just the file with all lines commented out:
Open/unsecured
#network={
ssid="put SSID here"
key_mgmt=NONE
Also the country is still GB
So I edit the file using Notepad++ putting in the wifi password and ssid and US as the country and comment out GB.
loaded the sd card into my new raspberry pi 4B and It does not show up on the network. I have run Angry ip Scanner and it doesn't show up. I have Octopi running on a laptop but want to use the Raspberry Pi
By the way I also ran the imager to install Raspberry Pi OS and checked the file First-Run and in that file I found it did write in the country as US and also had the correct ssid and password(?encrypted)
What do I do now?
NO
If I cant find it on the network how do I run in safe mode?
Octoprint version is whatever version Raspberry Imager puts on the sd card I guess it's the latest as of Oct.28,2021
Doing the above Im on Windows 10 using chrome
