OctoPi can't see serial port
My printer is on and connected, Octopi is set up properly, and yet I get an error saying:
" No serial port found, are you sure your printer is physically connected and supported? Try [refreshing](javascript:void(0)) and if that doesn't help please see the FAQ. "
In the connection tab.
I updated my printer's firmware, I followed the FAQ and I tried pronterface. My printer doesn't show up as a serial port
Yes, but I get the same error
octoprint-systeminfo-20251209131832.zip (16.8 KB)
octoprint.log (104.6 KB)
serial.log (373 Bytes)
tornado.log (68.7 KB)
OctoPrint version & Octopi version
OctoPrint 1.11.5Python 3.11.2OctoPi* 1.1.0 (build 2025.12.01.130812
Ender 3 Pro Marlin 4.2.2 firmware
Firefox browser
Manjaro Linux KDE OS,
Hello @feeish !
Does it show up there?
Have you tried different USB cables? Some only deliver power but no data.
Unplug your printer and then type sudo dmesg --clear. With the printer powered on, plug it in. Type dmesg, capture the output and post it here using the </> preformatted text tool.
If there is no output, then the USB cable is a power only cable.
I can mark this as solved. The data cables (3 that I purchased which were marked as such) were defective. The electronics shop I bought them from had a cable validator. Apparently they were all mismarked and were all only power cables and NOT data cables as they were advertised.
Got a proper data cable and it all works now.
