Octopi works fine via USB. Trying to connect Octopi to my SKR Mini E3 V3 via the GPIO/TFT pins but it doesn't want to connect. I used the steps provided by Chris in his youtube video.
I don't know where to begin. I'm not very knowledgable about programing Rasp Pi's.
No.
n/a
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36
connectivity.connection_check: 10.0.0.218:22
connectivity.enabled: False
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 914006016
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.2
printer.firmware: Marlin bugfix-2.1.x (Sep 17 2023 16:04:12)
systeminfo.generated: 2023-09-20T22:13:21Z
systeminfo.generator: zipapi
Ender 3 Pro.
The serial log from connection attempt:
2023-09-20 22:57:19,073 - Enabling serial logging
2023-09-20 22:57:26,531 - Changing monitoring state from "Offline" to "Opening serial connection"
2023-09-20 22:57:26,541 - Connecting to port /dev/ttyAMA0, baudrate 115200
2023-09-20 22:57:26,574 - Changing monitoring state from "Opening serial connection" to "Connecting"
2023-09-20 22:57:26,579 - Connected to: Serial<id=0x65e83a90, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2023-09-20 22:57:26,596 - Send: N0 M110 N0125
2023-09-20 22:57:26,601 - Send: N0 M110 N0125
2023-09-20 22:57:56,639 - No answer from the printer within the connection timeout, trying another hello
2023-09-20 22:57:56,657 - Send: N0 M110 N0*125
2023-09-20 22:58:06,663 - There was a timeout while trying to connect to the printer
2023-09-20 22:58:06,674 - Changing monitoring state from "Connecting" to "Offline"
2023-09-20 22:58:06,703 - Connection closed, closing down monitor
